1. As mentioned, turn off he caps. In the on line world, that's sonsidered shouting and is seen as rude. It's also harder to read.
2. You can post more than one picture in each post. Having them all togethere makes looking at them easier.
3. If a picture is way out of focus, like the first one, retake the picture and post a good one up. It's hard to ceommnet/appreciate something when you can't make out the details.
4. Your .50's need a lot of work. There are seams on both receivers. The handle on the one on the right is way off center and the handle on the other one is broken.
You might want to check your references on the quote in your signature. The earliest citation for that quote in 1968 from Eldridge Cleaver.
