yellowed siding - need help
    April 2010
Posted by Shuttle1909 on Saturday, April 17, 2010 8:09 PM
About 20 years ago I built a scale model of the house I grew up in.  Including landscaping, the model itself is about 38"x42" and has been covered with 1/4" plexiglass.  I have a 1/64 scale car in the drive-way which is a close fit (not exact); so the model is probably close to that scale.   In getting it ready to take to my brother (about 8 hours away), I've noticed some "aging" to the model.  The most annoying thing I've seen is the siding on the house and garage is yellowing in areas.
I don't remember manufacturer specifics, but the siding is thin, molded plastic and does resemble vinyl siding on a house.  It is glued over a wood frame, but don't remember what type of glue I used.  I've tried using rubbing alcohol and Goof-off (which was a mistake) to remove the "stains" without success or luck.
Any suggestions?
Thanks!
Rob
    October 2009
Posted by Macktheknife on Sunday, April 18, 2010 1:50 AM
Unfortunately, that yellowing is probably ultraviolet light damage to the vinyl - I'm not sure you could do anything about it short of repainting.
    April 2004
Posted by vespa boy on Monday, April 19, 2010 4:39 PM
Often,  plastics yellow when they are stored in the dark, but this doesn't sound like the case here. If it has been in a Plexiglas box, it probably has been shielded from most UV light. Heat can also induce yellowness in plastics.
My guess is that the plastic has degraded and that you will not be able to do anything about it apart from replace the parts. You can accept the changes and call it patina.
One last thing, if it is oozing a sticky substance, wear gloves, this is the plasticizer migrating to the surface. They are often nasty chemicals which you don't want in contact with your body.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    April 2010
Posted by Shuttle1909 on Friday, April 30, 2010 10:19 AM
Thanks for your suggestions.  The only thing "oozing or gooey" was AFTER I tried Goof-Off, fortunately on the back of a building.  Before loading the model for the trip, I did try Windex - no luck there either.  The model has been successfully moved and I did point out the yellowing to my brother.  He remembers re-painting the actual house  back in the '70's and since the house was built prior to the 1850's, he contributes that the yellowing indicates the actual house just needs a new paint job, LOL!  As in he's looking at the yellowing as more authentic to the house.
Hopefully someday my nephews will take up model building (ages 12 & 13 now).  Besides fixing up the house model, I've got many more models for them when I "kick the bucket."
I'm glad I found this site and although I don't build models as frequently as I used to, I'm sure I'll have other questions or things to look up in the future.
Thanks!
Rob
