What can i use for...
Posted by Anonymous on Tuesday, January 6, 2004 7:54 PM
water, can i use a resin of somesort, im doing a dio of a crashed huey on a side bank with a "pibber" near by, is ther any paticular type of reasin??? please help and many thanks
Radleigh...Smile [:)]
Posted by Anonymous on Tuesday, January 6, 2004 9:16 PM
Radleigh, There are many different ways to make water for dioramas, but for large and deep water, 2 part (resin and catalyst) polyester resin is probably the best choice. This stuff can be found in art supply stores, auto part and boat shops, craft stores and hardware stores. It is normally used to cast objects from molds or to make fiberglass objects. It can be tinted with available dyes or even food coloring. Follow the directions carefully. Too much catalyst and it will crack and craze. Too little and it will remain sticky forever! Work in layers of only about 3mm at a time. Paint the basin in which you want the water a muddy brown, lightening towards the edges, and let thoroughly dry. Mix and pour, then pick up the diorama and gently tilt it to let the resin flow into all nooks and crannies. Set on a level surface to harden, about 48 hours.
Posted by mark956 on Wednesday, January 7, 2004 12:07 AM
Radders84, Woodland scenics makes a product called Realistic water. I have not used it, but have read that this product is real good. Oh yah welcome to the FSM forums.
mark956
Posted by Anonymous on Wednesday, January 7, 2004 9:12 AM
thanx guys , this site looks wicked too looking forward to more
Posted by Anonymous on Wednesday, January 7, 2004 11:51 AM
I would stay away from the 2 part casting resin for deep water. If you aren't careful with the mixing proportions, it can get really hot and I have seen it shrink from the heat.
The Woodland Scenics water is a simple and "low temp" method.
Posted by Anonymous on Friday, January 9, 2004 8:41 AM
I vote for the Woodland Scenics too! just used for WWI crater filled with water-worked great!
