Somewhere beyond the Nickel Belt
    September 2003
Posted by dpty_dawg_ca on Friday, January 28, 2011 9:02 AM
Diesel Generating Station
Somewhere in the hinterlands of Ontario, well beyond the reach of Hydro One's power lines, the Acme Resource Extraction Company has built a diesel powered generating station to power its mining operations. The power plant consists of a pair of V10 Sulzer gensets (one of which is off stage in this diorama) for primary power and a 3516B Cat genset as an Emergency back-up. All are enclosed in a metal clad steel building.
This 1/25th scale diorama is a section of this operation. The operators in the process of bringing the Sulzer Diesel on line.
Models Used:
3516B Caterpillar generator is a Norscot diecast
Sulzer V10 Generator is from the Revell Germany 6-axle Flatbed Trailer kit
Evergreen and Plastruct structural styrene
Walter's HO scale refinery piping kit
Many, many items from the parts box
Other than the two basic models everything else has been scratch built.
This is an overhead shot of the plant layout. The Cat unit is self sufficient but the Sulzers require many auxillary services to operate.
The Norscot diecast 3516B genset. I added the battery bank and exhaust stacks. Red pipes are firewater sprinklers. The ladder leads to a maintenance platform and roll-up door that leads to the cooling tower.
The cooling tower for the Sulzer Gensets. It cools the engines as well as the lube oil and generators.
The Sulzer genset with lube oil and stator cooling heat exchangers. Green piping is cooling water, Yellow is lube oil.
Front end of Sulzer with inter-cooler and cooling water circulating pumps. The operators are making adjustments to the intercooler's cooling water temperature control valve.
the Generator ends of both machines
The V10 Genset that Revell included in the flatbed trailer kit does not appear to be based on a prototype. It looks like it might be based on a V12 or V16 Sulzer machine. That's what I went with. Scratch built items are built on the scale of 1 mm = 1" (1/25.4) I tried to create a reasonable representation of a powerhouse in this diorama, however I didn't let the laws of Heat and Thermal or Fluid Mechanics get in the way of a good story.
Since this is a new power plant and the operators take pride in their equipment That means that there is a minimum of weathering required.
Thanks for looking
Carl
    October 2009
Posted by DrShrinker on Friday, January 28, 2011 11:58 AM
Neat.
    April 2004
Posted by vespa boy on Monday, January 31, 2011 3:57 PM
Carl, I love these industrial dioramas you build. This one belongs in a science museum. The only thing I would suggest is that the figures don't add anything to it for me. I know they add scale, but they don't measure up to high quality of the rest of the build. I hope that was okay to say.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    September 2003
Posted by dpty_dawg_ca on Monday, January 31, 2011 8:09 PM
Thanks N for the kind words.
 Your right about the figures. They have been improved upon a bit since these pictures were taken. The two operators in the forground are soft plastic toy figures that I added a bit of paint too. The girl's upper torso came from a skateboarding kids toy. The lower torso is from an old Kellog's cerial toy of a tennis player. The fit and pose was almost perfect. The male figure came with some construction toys. Both scale out to be about 1/25th scale and figures in this scale are limited . The soft plastic that they use in these things doesn't lend itself to much detail or repositioning so they look a bit chinchy.  But, I always think that there should be a human figure in a diorama to emphasise the machine.
Thanks
Carl
    November 2008
Posted by 3rdlav on Wednesday, February 2, 2011 9:04 PM
Looks great.But the equipment is going to run hot.Because its never worm enough for women"I'm cold" Zip it!Oops Did i say that out loud.
