Hey, sorry for the long absents. Thanks for taking a look and good to hear someone likes it.
Andy - The tall grass was probably the easiest part. Used Woodland Scenics "Field Grass" Held a clump between fingers, pulled from the bottom to make the grass uneven then cut at the base of the grass at the length wanted. Dap a spot of Hob-E-Tac onto the dio then stick the grass into place. After dry use AB to paint.
3rdlav - The figures are still under construction. Did manage to get a base coat onto one of them.
Thanks to you both for stopping in.
Rob
