Best base coat for a house
    June 2006
Posted by Tankluver on Monday, February 7, 2011 6:51 PM
Im building a house for a diorama and am ready to paint it. I was thinking of doing a Red Brown base coat.  But upon looking at mini arts tutorial i saw that the builder painted the base coat of the house a panzer grey? What do you guys suggest?
    April 2008
Posted by smeagol the vile on Tuesday, February 8, 2011 3:50 AM
well it depends.  Primer and Base coat are different things.  What color do you want the house?  Is it brick? stucko? wood?  that all depends.  Prime it in gray or white depending (gray makes the colors more dull, white makes them more vibrant)  then use a base coat near what you want, then detail over it.
FOR EXAMPLE
Mini art destroyed church.
Primed in gray, base coated in a brick red from humbrol, and the windows in a light gray from humbrol.
After that I used acrylics and oils to add shade and shadow to the bricks, windows, corners and whatnot.
the basecoat is just that, a base color to work ontop of
    March 2008
Posted by EasyMike on Tuesday, February 8, 2011 7:41 AM
You may not need a primer.  What materials did you use to contruct your house?
Smile
    June 2006
Posted by Tankluver on Tuesday, February 8, 2011 9:20 AM
I made it with some plastic sheets that you can buy at my lhs. I then covered it in squadron epoxy putty and smoothed it out to make it look like stucco.
Posted by Anonymous on Tuesday, February 8, 2011 9:24 AM
I use either panzer grey, black or a dark brown when basecoating buildings...
