Acrylic Rod for display stand
    February 2011
Posted by Wyldoming man on Friday, February 25, 2011 5:32 PM
In past issues there have been articles referring to using Acrylic Rod to display aircraft in flight. I've been trying to find some and haven't been able to locate any. Does anyone know where I can get some?
Thanks.
    January 2006
Posted by dirkpitt77 on Friday, February 25, 2011 6:04 PM
I get mine at the local plastics shop here in Ft. Collins.  I'd say Google it up and see what pops up under "plastics" for your area.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    January 2009
Posted by Division 6 on Friday, February 25, 2011 6:46 PM
Tower Hobbies has Plastruct 1/4" x 9 1/4"  10 pack for $4.49,
I picked up a pack last month.
    August 2005
Posted by EdGrune on Sunday, February 27, 2011 2:31 PM
My LHS carries it in the Plastruct display,   several diameters in clear,  blue,  yellow & hot pink
    March 2010
Posted by macattack80 on Sunday, February 27, 2011 3:12 PM
http://www.estreetplastics.com/    I ordered from these guys a few times in the past.  Nice products.  They will cut to any size as well.  I bought some acrylic sheets that I use as shelving to display built models.
Just an idea.
Kevin
    January 2008
Posted by somenewguy on Tuesday, March 1, 2011 10:37 AM
If I may add a question, where can curved acrylic rod be found? In the July 2007 issue of FSM Pat Hawkey built an X-15 and displayed it in flight with a curved acrylic rod mounted in the back of the plastic base and shoved up the X-15's exhaust with interior reinforcement. Looks really good and I want to give it a try but need the curved stuff first.
Thanks.
At the end of the day one's work may be completed but one's education never!
    February 2011
Posted by Wyldoming man on Tuesday, March 1, 2011 10:47 AM
You must have read the same issue I did. It looked great. I haven't found any curved rod but I went on Ebay and found some from Discount Plastics Inc. I ordered the 1/2" X 72". They have a wide variety of sizes both solid and with a hole through the ID (which might work for fiber optics). I'm going to try and heat mine up with a heat gun and try shaping it to how I need.
    August 2005
Posted by EdGrune on Wednesday, March 2, 2011 7:28 AM
I've curved the Plastruct rod using the kitchen stove.   Twirl the rod while heating like you would a piece of sprue being stretched.    Don't let it get too hot or it will bubble & discolor.   When soft bend it around a soup can or similar to get a smooth, even bend.
A workshop heat gun should also work,  but keep the piece moving in the heated air stream to prevent bubbles.
I think commercial plastic benders use a hot sand bath to provide an even heat soak
    August 2006
Posted by HawkeyeHobbies on Wednesday, March 2, 2011 7:32 AM
Visit your local department store, check the aisle where they sell curtain stuff. There you'll find acrylic rod which is used to open and close blinds and curtains. Cheap.
Gerald "Hawkeye" Voigt
dmk
    September 2008
Posted by dmk on Wednesday, March 2, 2011 8:06 AM
EdGrune
Let me add one thing to this:
 Before shaping your acrylic, try out your shape with a piece of wire (a section of coat hanger would probably be best, though stiff electrical house wire may work).  Use the wire to make sure your shape will be the appropriate dimensions, will balance your model properly, etc. It will be much easier to make adjustments to the wire.
Once you have your shape correct with the wire, use it as a template for your acrylic.
