Diorama Base Painting Help
Posted by kielers on Wednesday, May 25, 2011 7:06 AM
I have a resin PSP diorama base but am not sure how to paint the groundwork.  I want to put a Pacific Theater P-40N (New Zealand area) on it.
Can someone give me a little advice on what colors to use, the order in painting them on, washes, dry-brushing, etc. for the groundwork part of the base?  I think it's mostly rock and/or bare ground, what would normally be immediately surrounding the PSP.
Thanks for your help.
"To stand upon ramparts and die for our principles is heroic, but to sally forth to battle and win for our principles is something more than heroic." -- Franklin Delano Roosevelt. "Never in the field of human conflict was so much owed by so many to so few." -- Winston Churchill
    September 2007
Posted by SuppressionFire on Wednesday, May 25, 2011 7:19 AM
Start with a deciding which type of soil or look you want to achieve. I know `red dirt`is common down under so a red oxide primer is a good start.
Follow with a Red - Brown wash. Then dry brush the tops a lighter color for contrast. Now add any vegetation or grass on top of the soil & rock. Add larger elements after the lower ground work is complete.
Basically its the same sequence as planting a garden. Get the soil & dirt looking right before transplanting on top of it, larger items take longer & more effort so they would naturally come later.
The same sequence was done for this lill`scene in 1-144 scale. The only difference is tones of gray were used instead of reds. Shrubs & grass are easier in smaller scales, here model RR scenic ground work was used.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
