Ok, sign up here...
There will be two prizes: First Place will receive a classic Monogram kit originally featured in one of Shep Paine's outstanding Monogram dioramas... Will be either 1/48th aircraft or 1/32-1/35 AFV (your choice of genre, my choice of kit)...
Last Place will receive a copy of Shep Paine's How to build Dioramas.
Contest runs from 1 SEP 11 to 30 April 12 (The 229 was a gag..) Deadline for signing up is 30 SEP 11. After then, no one else will be competeing. You got all fall, winter, and most of spring to get it done...
The rules are simple..
1: Only ONE diorama per entrant. You can build more than one and submit the best one.
2: No Cross-overs from other GBs allowed, except for using the models from another GB as part of this one.
3: EVERYTHING on the diorama will be judged. That includes the base. Bases can be any material or shape. They won't be judged in the classic sense, but every picture needs a frame, if ya get my drift...
4: Judge's decision is final. He's also always right.
5: If you disagree with any of the judge's rulings, see Rule 4.
6: All genres and scales are open.. Military, civilian, Sci-fi, Space, etc. Shadow-boxes are allowed.
7: Models on the dio may be SOB (Straight Outta Box) or loaded with AM parts.
8: Start from scratch. (While this is a rule, it's more of a suggestion. You got a lot of time, no need to re-vamp an old one, but if that's all you got, well.. We're on the "Honor System" here.. But I'll notice... )
9: Photos- You need the following at a MINIMUM: Three wide-shots showing the entire dio. Then, Ten close-ups. The higher the res, the better. Or maybe it isn't, lol... But no blurry shots. Take your time and think about the photos.
10: Backgrounds will be a light color, preferable light blue or white. No photo-shopping backgrounds. Photos may be taken outdoors to use natural light, but no natural backgrounds. All I wanna see is your dio and the afore-mentioned light backgrounds. No special effects. (No adding smoke, spinning props, or dust, etc. Save that for later, when we have the Diorama Photo Contest)
11: Dioramas will be no larger than 36" x 36".
12: There are two diorama-size categories: Smaller than 225 square inches. Larger than 225 square inches.
13: Prizes will be awarded for each size-category.
14: Reserved for future use
15: Reserved for future use.
I'll polish the rules up more in a day or so... Meanwhile, start signing up! (You don't need to list models used unless you want to. Keep the story-line to yourself though. We want to be surprised!)
I've added the names of those that said "OK" in the other thread.. Lemme know if you changed your mind, and I'll remove you. Also, while keep ing your dio a secret, please add what genre you're doing, ie; Military (state era, WW2, Korean War, GWOT, Cold War, etc), Civilian, Automotive, Real Space, Sci-Fi, Misc., etc.. Don't need any more info than that.
You may change you genre and/or era any time up to the sign-up deadline of 30SEP11. After that date, you're locked in.
ROSTER
Hans von Hammer- Military, WW2 (Recused-Not Competing)
Subhuman1-Military, WW2.
Bish-Military, WW2.
Kermit- Military, WW2
Sanderson 91- Military, WW2
101st Airborne-
Troublemaker- Military, WW2
Ruddratt-Sci-Fi
Tal Afar Dave-
Vespa Boy- Misc.
Dre-TBA
Deputy Dawg CA- Civilian
Bondoman- Military, WW2
K-Dawg- Military-WW2
Chewybr-Military, WW2
Kveldulfr-Military, WW2
General Dodonna- Military, TBA
Andy T(+1)- Misc,Nature
Satch Ip- Military, WW2
P38Jl-Military, WW2
Razorboy-Military,WW2
DosTacos-Military, WW2
SteveM- Military, WW2
Castelnuovo - TBA
