In flight aircraft stand
    September 2011
Posted by jpillsander on Saturday, September 10, 2011 8:26 AM
Hi FSM Forums,
There might already be a thread.  I want to make a stand for my B-24 so it looks like it is in flight. Any ideas how to attach the wire to the airplane? I have a piece of wood with a hole drilled in it for the wire, but I cant quite figure out the best way to attach it to the plane without breaking it.
Any ideas and suggestions would be much appreciated.
Happy Modeling
Josh
    October 2003
Posted by masonme2 on Saturday, September 10, 2011 8:40 AM
That's going to be a tough one because the B-24 is such a big plane. You don't say what scale it is but I'm guessing 1/72 since anything bigger would seem to be out of the question. While you are building your kit try to plan some sort of reinforcement into the fuselage to use as an attachment point. You will need to try and find the center of gravity for easier balance and then you should be able to get by with a small mounting hole that won't detract from your model. If the plane is already built that will make things a little harder. If you get it done lease post a pic. so we can see how it turned out. Good Luck!
"Diplomacy is the art of saying 'Nice doggie' until you can find a rock"   Will Rogers
    June 2008
Posted by Hans von Hammer on Saturday, September 10, 2011 1:34 PM
1/2" Acrylic rod attached to bottom of the plane at its CoG is your best bet (if its 1/48th)... Anything else is gonna be wobbly and/or unsightly, IMHO... Were I doing it, I'd cut it at an angle, running from somewhere near the bomb bay at a 30-deg. angle or so... You can go with a smaller-diameter rod if it's 1/72..
Since it sounds as if you already built it, attaching it to the plane is gonna be the major hurdle... Some type of two-part epoxy will be the likely candidate...
You'll also need to ensure that the base is big enough to support it without tipping.
Another option would be a wire or thermo-formed acrylic rod inserted through the tail thusly:
 You'll want the rod or wire inserted far enough inside that the weight is taken by the top of the fuselage and not the tail..
    January 2009
Posted by fermis on Sunday, September 11, 2011 3:31 PM
For these, I used brass rod. Just drilled a hole the exact same diameter as the rod, at the angle I wanted the planes to sit. The fit is tight enough to hold them in place, and they can be removed easily enough.
I used 1/4" wood dowel for this F-16. Same deal, drilled a 1/4" hole at an angle, tight fit, needs to be twisted around to slide down on dowel.
Posted by BaBill212 on Sunday, September 11, 2011 4:21 PM
First,,,,  seeing this is your initial post, I would like to welcome you to the forums Josh, glad to have you with us.
The gentlemen's preceding replies have covered the way I also like to pose "wheels up" so to speak.  While this picture is not good,,,  it reflects the general idea.
 Best of luck with the project and be sure to post some photos,,,,  we all like the pics!
Bill
Enjoy the ride!
    September 2011
Posted by jpillsander on Monday, September 12, 2011 8:39 AM
Thank you everyone for your great suggestions. I cant wait to go to the hardware store to pick up supplies. The B-24 is in 1/72 scale. The Dragon and his Tail. Its been years since I made a model. It was a great learning experience.I really appreciate the help.
Im partial to the B-24 because my Grandfather was a waist gunner. I made this model for him, although his aircraft was dessert pink not metal. He said they found out the paint added drag to the aircraft so they went to naked metal.  He flew in Africa and later Eastern Europe. Ive included a picture of a page from his mission log book.
Happy Modeling
Josh
[View:/themes/fsm/utility/Photobucket:550:0]
    January 2010
Posted by 101stAirborne on Monday, September 12, 2011 6:16 PM
The Model looks great! How did you paint the aluminum color? it looks great!
Models on the bench:
Too many to count!
    April 2009
Posted by Cadet Chuck on Monday, September 12, 2011 6:32 PM
Another idea to consider is a wall-mount.  I have made a few using a wooden plaque, mounted to the wall, with a wooden arm sticking out, the model is mounted on a couple of screws or pins on the end of the arm, at an angle to the wall. The arm can also be hinged in the middle, to allow you to adjust the position of the aircraft.  Sorry I don't have a pix to send.
    September 2011
Posted by jpillsander on Wednesday, September 14, 2011 8:54 AM
Here is the finished model. I used Testors Silver with paint thinner (1 part paint 2-3 parts thinner) . It took three coats. Painted quickly so it covers more evenly. Saving to buy an airbrush. I also applied Futures floor polish on the main body and glass. I saw a video on youtube about the futures. It does a great job making windshields shiny and glass like. It also helps cover minor scratches. I bought it at ace hard ware for $4.
The stand is painted gloss black. I drilled a hole the same size as the wood dowel in the fuselage and base. I then applied a good amount of two part epoxy. Still have some minor cleaning/touch up to do.
    March 2005
Posted by mfsob on Wednesday, September 14, 2011 9:35 AM
The stand really makes your model stand out. Well done - Yes
    August 2006
Posted by HawkeyeHobbies on Wednesday, September 14, 2011 2:43 PM
Think how they mount real aircraft at museums and as gate guards. Replicate that.
Example: Malmstrom AFB MT this F-101 is mounted on post fastened to where the landing gear are hinged inside the aircraft.
The B-25 in the background is set on risers connected to the landing gear...the wheels are not resting on the cement. I was at Malmstrom when the B-25 was donated. It sat on the ramp for some time while the transfer paperwork and aircraft could be prepped...they flew it in. The metal posts from the cement footings were not painted at the time of the dedication. Surprise to those attending...Product of Japan was stenciled on the steel! The irony of the first US Bomber to attack Japan, which attacked the US with machines made from steel scrap acquired from the US.
Gerald "Hawkeye" Voigt
    January 2010
Posted by 101stAirborne on Thursday, September 15, 2011 6:47 PM
I found a great website with bases for this need. visit fascinations.com They have a base called a levitron that actually floats your model using magnets!
Too many to count!
    July 2011
Posted by prush on Monday, September 26, 2011 5:51 PM
I dont know where you are from...but are you aware that that aircraft is part of the "Confederate Air Force" and tours the United States every Year.
It usually shows up here every spring at the local flyin, with a B-17.
You can tour the inside of the plane for a small fee..(maybe even free).
you can also buy a ticket and take a 20 mnute flight...
Last time I saw it, it cost $400 for that 20 minute flight.
    August 2006
Posted by HawkeyeHobbies on Monday, September 26, 2011 6:27 PM
prush
It is no longer know as the Confederate Air Force but now know as the Commemorative Air Force...being a Confederate isn't politically correct. So as to not offend spectators and  potential contributors...they changed the name.
    July 2011
Posted by prush on Monday, September 26, 2011 6:48 PM
Well, I am from Virginia, so "Confederate" is still in my vocabularyBig Smile
Anyway, here are a couple pics from the last time they were in town.
    October 2011
Posted by OldFart on Monday, October 3, 2011 1:16 AM
For what it's worth.....The Heavy Iron shown is owned and operated by the Collings Foundation. The B-24 is now flying in the colors of Witchcraft. A really neat colof scheme.
    June 2008
Posted by Hans von Hammer on Tuesday, October 4, 2011 12:07 AM
Also, the CAF doesn't own or operate either of those aircraft...
"OL'927" is the B-29A the CAF flies (FKA "Diamond Lil"),
and the two CAF B-17s are "Sentimental Journey" and "Texas Raiders"...
Hans von Hammer
Colonel, CAF
Posted by tigerman on Tuesday, October 4, 2011 12:22 AM
I'm no prude, but that's pretty racy nose-art. LOL Explain that to junior.
Nice model btw. I've always favored the 24 over the 17 myself.
 Eric
