I have in my stash the old Gunze-Sangyo kit of a partial crashed Bf-109G with the pilot running away from it. The vignette that this kit presents will be expanded upon to include two vehicles (I might have to make some of the damage aircraft parts as well), a Kettenkraftrad and a Pz II Luchs. All vehicles are from my stash.
The plane will be placed into the back left corner of the diorama with ample ground damage to show the skidding across the terrain. From the aircraft, the pilot is running to the Kettenkraftrad which has just turned around to face the right side of the diorama, Only the driver will be in this vehicle.
At the center front of the scene will be the Luchs. It will be turned with the left front pointing towards a "heads on" viewer. The turret will be also turned to over this corner of the vehicle as well. The tank commander is leaning out of the turret with binoculars viewing the oncoming enemy (probably Russian) ready to order the gun to fire on them or to make a hasty return to safety. The track marks on the ground should add emphasis to the siftness of the action going on.
Some of the titles I have been thinking of is "Grab and Run!" , "A Quick Pickup", or "Taxi Anyone!"
Mike T.
Beware the hobby that eats. - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
