Flames tutorial
    February 2007
Flames tutorial
Posted by T-rex on Tuesday, November 1, 2011 9:17 PM
As my latest build , (the OT-26 ) is nearing completion, I just want to share my technique of making flames for diorama's
I haven't hear or even seen good looking fire in a dio, usually it is hidden by thick black smoke, but for this build, I wanted to see the flames.
I purchase this kit because it was cheap, and I've never seen an OT-26 because, or even heard about it. and while it may be a bad quality kit, its certainly easy so assemble. And I knew a blazing diorama, would make it stand out, so I had this idea from the start.
After assembling the turret, I drilled a small hole where the nozzle was and fitted a copper wire, after painting the turret, it was time to starts the ''body'' of the flames, I thought that making the correct characteristic of the flames difficult, but it is like water, so woodland scenic water effect glue (a sort of latex plastic that turns transparent when dry) is perfect.
Once dry, painting can begin. Base coat is yellow, follow by dry brush red and orange. Not the best loking flames, but it turn out better than expected.Huh?
And thats basicly it, if there are anyother technique, please feel free to share them, I might use then in a futur build.
Thanks all.
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
    January 2008
Posted by Bodge on Wednesday, November 2, 2011 12:36 PM
Not bad at all that. well done mate.Big Smile
Posted by Tojo72 on Wednesday, November 2, 2011 12:43 PM
pretty nice Yes
    March 2010
Posted by Hercmech on Wednesday, November 2, 2011 2:49 PM
Very cool tip
13151015
    June 2008
Posted by Hans von Hammer on Thursday, November 3, 2011 1:36 PM
I haven't hear or even seen good looking fire in a dio...
That's because most folks forget the key element to making fire look right...
Light...
I've had pretty good success in the past with using grain-of-wheat bulbs and LEDs along with spun-glass "angel's hair", but my supply of the stuff dried up years ago (I got it from an old Christmas Tree topper)...
Never tried a "stream" of flame though.. Did cooking and fireplace fires, and few muzzle-flashes... Worked pretty good too, but I have no idea where to look for the stuff anymore.. Fiberglass insulation doesn't work at all, because the strands are too big and the light doesn't difuse well enough to "light" the whole thing up...
    February 2007
Posted by T-rex on Thursday, November 3, 2011 8:55 PM
I knew that for this tank, it was crucial that it look like a stream of flammable liquid coming out of the nozzle, but I didn't know the range of the OT-26, the kit says '' Capable of firing 70 shots''. What does it mean shot? its not a cannon, its a flame thrower, how does that make senses?
Well in this scene the tank is covering a enemy trench (as seen on its left). I,m stil working on the grounds work, and hopefully it will look good.
Post it when its done. Cool
Posted by Gamera on Friday, November 4, 2011 10:34 AM
Pretty darn cool, other than all the black smoke (not sure how you'd model that) it looks like the flamethrowers I've seen fired in demos.
    June 2008
Posted by Hans von Hammer on Friday, November 4, 2011 11:03 AM
"Shots" are simply  X-number of seconds'-worth of fuel fired in a stream... Say each stream is three-seconds in duration, and it can do that 70 times before the fuel is exhausted.
IIRC, there's also a built-in safety (dunno if it's on one of these or not) that limits the amount of fuel that can be "shot" each time the trigger is pulled as well, to prevent "back-flowing" of the fire-stream in case of propellant-gas or pump pressure loss...
