How would you simulate a drip of glue or goop or other thick liquid?
    January 2006
Posted by dirkpitt77 on Sunday, February 5, 2012 6:37 PM
     Hey guys,
    Working on a large figure kit, and I need to simulate the drip of a clear, thick goop from the tube in the figure's hand to the ground.   I was thinking of using fishing line with knots tied in it, and stretching that from the hand to the ground.  Then I would trickle clear epoxy down the fishing line to hide and thicken it, and give it a fluid look.  What do you think of this plan?  Is there another, better way?   What say you?  :)
  --Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    March 2008
Posted by EasyMike on Thursday, February 9, 2012 8:35 AM
Skip the epoxy.  Use clear resin.
Smile
    April 2004
Posted by vespa boy on Thursday, February 9, 2012 2:52 PM
I know that Ken Hamilton has used 5 minute epoxy to make icicles, which is essentially an upside-down drip.
I have also played around with 5 min epoxy and I think it may be the way to go for your application. Just as the epoxy is setting you can draw it up and shape it with a toothpick, its like working with toffee. Let that dry and mix up a new batch and you can add details. Because you are using the same material it should all blend together seamlessly. Give it a shot, at worst you have wasted 15-30 mins.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    January 2003
Posted by TomZ2 on Thursday, February 9, 2012 4:38 PM
EasyMike
Smile
Ditto
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    January 2006
Posted by dirkpitt77 on Thursday, February 9, 2012 7:45 PM
    I meant clear resin!  LOL   I tried a first layer of Envirotex, but it takes too long to cure.  Then I switched to ModPodge, and that stuff has been curing in about an hour per layer, so I went with it.  I have three layers on and we're looking good.  Thanks guys!
--Chris
    August 2006
Posted by HawkeyeHobbies on Friday, February 10, 2012 1:06 PM
Make it by stretching clear or white sprue. Paint as needed if needed.
Gerald "Hawkeye" Voigt
Posted by Anonymous on Friday, February 10, 2012 1:08 PM
With a drip of glue or goop or other thick liquid...
