Terrain Technique Question - Smoothing Out the Rough Spots
Rej
    February 2012
Posted by Rej on Thursday, April 19, 2012 7:36 PM
I am modeling a golf course using Sculptamold as the building medium. I smoothed it out as best I could by rubbing the surface as it was setting, and doing some light sanding. That did a good job knocking down the high spots, but I'm finding there are still small pits and divots in the surface which would spoil the "pool table" smooth surface when I flock it.
I need a way to smooth out the rough spots. I'm looking for a (preferrably) sandable thin-coat material that I could brush onto the surface and that will settle into the pits and divots. Also, I prefer it to be flexible, or at least non-shrink, so that small cracks don't form
Looking for help from experienced modelers. Thanks!
Tags: Dioramas
    September 2003
Posted by dpty_dawg_ca on Thursday, April 19, 2012 9:15 PM
Drywall taping compound works well as a terrain body filler. easy to apply with a spatula and sands easily too. It comes premixed in small plastic pails and is available at any hardware or building centre.
Carl
Rej
    February 2012
Posted by Rej on Thursday, April 19, 2012 10:53 PM
Thanks Carl. I'll give it a shot. Wondering if you or anyone else are familiar with a product I found called Red Devil "One Time" Lightweight Spackle. It seems to be some type of plasticized vinyl. Maybe I'm better off sticking to a standard gypsum based joint compound. But the spackle seems to have greater potential to go on super smooth. Thanks again.
Rej
    March 2008
Posted by EasyMike on Friday, April 20, 2012 6:56 AM
Rej
... Wondering if you or anyone else are familiar with a product I found called Red Devil "One Time" Lightweight Spackle. It seems to be some type of plasticized vinyl...
I have used it for it's intended purpose.  It tends to dry too quickly and begins to crumble as it dries.
... Maybe I'm better off sticking to a standard gypsum based joint compound...
Yep.
    March 2008
Posted by EasyMike on Friday, April 20, 2012 6:57 AM
Rej
Yep.
Rej
    February 2012
Posted by Rej on Saturday, April 21, 2012 8:54 AM
Thank you, sir.
