Verlinden question
    October 2009
Verlinden question
Posted by Kentucky Colonel on Saturday, April 28, 2012 5:21 PM
I have a Verlinden Resin building and base that I want to get staeted and I have a question.
Do you all just use epoxy to put the building together with the base or do some of you also add some kind of pins in the walls to give it a little more support? If so how is that done.
I guess what I'm trying to ask is how do you all put these together.
    April 2012
Posted by Reserve on Saturday, April 28, 2012 10:14 PM
On resin I use the thick slow cure cyanoacralyte glue. You could use epoxy also I guess but the CA is easier and you don't have to mix it. I've never bothered with pins as the glue is strong enough for the job at hand. Good luck with this.
Mark
