We'll go round and round with this one, as everyone has their favorite. I have used both for many years, but I now only use plaster, for several reasons. Not to say that celluclay doesn't have some distinct advantages, it does. The first and most important advantage celluclay has over plaster is working time. If you want to play with your groundwork all day, form terrain, change your mind and do something else, celluclay is what you need. Plaster's work time is very short, 10 minutes at best, so you better think out what you want to do with it long before you mix it up and throw it down. The other main advantage with celluclay is it's texture. It's already lumpy and bumpy and doesn't need much work to look like dirt, rock, mud or whatever you want. It's just a matter of tooling it or smoothing it into what you want. You can also mix dirt, sand, plaster, kitty litter, tree roots, static grass and a whole lot of other things into it to change the texture. That said, there are some things I don't like about it, the first of which is drying time. You really need to bake the stuff in the oven, otherwise it can take days or even weeks to thoroughly dry. But you better make sure your base won't warp and put down a big blob of white glue underneath the celluclay so it doesn't separate from the base when it dries. The other thing I don't like about celluclay is that I use a very wet technique when I paint my groundwork, using lots of washes, filters, airbrushing, drybrushing and everything else. All this water soaks back into the celluclay and we are back to a soggy blob again. This is why I now prefer plaster. It's quick, it drys fast, I like the way it paints up, and if I buy it bulk at the pottery supply store, cheap. I build up the topography with styrofoam blocks, cut them to rough shape, cover them with plaster bandage and then with a thin layer of plaster. Before the plaster sets, I sprinkle dry plaster through a tea-strainer onto the wet plaster. As this collects and hardens, it forms a finely grained surface which paints and dry-brushes very nicely. Both products work well, it's mainly personal preference in what you use.
