Last night, I bought a WWII memior book called "A Higher Call - An Incredible True Story of Combat and Chivalry in the War-Torn Skies of World War II " ( http://www.barnesandnoble.com/w/a-higher-call-adam-makos/1111307500?ean=9780425252864 )
I have been thinking of recreating an ambitious diorama based on this book using both planes in flight. The BF109 won't be a problem to build. However I am looking for idea/suggestions on how to go about recreating the battle scarred, crippled B-17F Fortress as portayed on the cover.
How do you create the damaged tail wing and rear stabilizer as well as the scarred fuselage? What kind of ways are there to create such heavy damage? Not sure how to go about it with applying decals. Would you put them on last?
Correct me if I'm wrong - is it true using a heated nail point to create fuselage pocked with bullet holes through out the fuselage? If there is a much better way, please advise.
What is the best way to create a stand with both planes in flight? What do you use to create spinning props as the aircraft is in flight? If there is a any references in how to create such heavy damage sections, please advise. This is most likely will be a long, slow project and I want to do take my time doing this - even if I'm building other kits in the process. I'm almost afraid to do it because I fear I may end up getting myself way over my head with this but I'm willing to try.
Decals for both aircrafts are availble for both the B-17F Fortress and BF-109. I am unsure whether to go with 1/72nd scale or 1/48th scale. Any advice, tricks, suggestions, encouragements are welcomed.
