Flying Cloud RV Camper Finished 06.12.2013
    December 2008
Posted by PatW on Friday, September 13, 2013 5:07 PM
I've just had this delivered from the states. It's a resin 1/24 - 1/25 scale model made for use in Diorama's so it's 10 inches long and 4 1/2 inches high. The detail is good. It has flash around the bottom of the casting OR is that grass and rubbish. OR should I fit it out knowing what we can get now from resin casters........
As you can see it also comes with a spare wheel with tyre and a couple of cooking gas cannisters. I had to wait a few weeks for it to come from teddyb2336 on ebay to here in the UK but it was worth it!
Remember , common sense is not common.
    January 2006
Posted by SprueOne on Sunday, September 15, 2013 3:17 PM
A Silverstream Cool
Is that solid or hollow inside? Yeah, details look alright and the air bubbles look minimal. I'm pretty sure that the flash around the bottom is not intended detail but part of the pouring block.
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    December 2008
Posted by PatW on Monday, October 28, 2013 4:25 PM
Hi SprueOne yes it's hollow, minimal pinholes, now filled and the plumbers tape works!
Right I can hopefully get the centre floor section in with the axle and wheels on, this week.
    March 2004
Posted by subfixer on Wednesday, October 30, 2013 3:36 PM
Lookin' quite spectacular so far. Yes
I'm from the government and I'm here to help.
    December 2008
Posted by PatW on Friday, November 1, 2013 4:46 PM
Thanks subfixer. Here's a few more pics. We have the wheels on, tow bar, front tray and camping gas cylinders.........
So there's just the tow hitch to finish and the lights and number plate.
Posted by HeavyArty on Friday, November 1, 2013 8:21 PM
Looking good, but I think you have the suspension too low.  There should be more of the wheel showing in the wheel well.  Here is how it should look.
    December 2008
Posted by PatW on Saturday, November 2, 2013 5:29 AM
D'you  know HeavyArty  I thought that! I'll see what I can do. Thanks.
Posted by CapnMac82 on Saturday, November 2, 2013 5:48 PM
The round-ish structure over the door on the right hand side is a rolled up fabric sun-shade.
The fabric rolls up on a central, lightly spring-loaded, winding axle.  The other edge fastens to the trailer.  This is fitted to a tube frame that hinges  to the trailer frame..  When the frame hinges out, and the fabric unrolls until the frame sticks out about 45ยบ from the trailer side.  The weight if the frame folds the awning open against the spring.
The frame usually looks a color much like galvanized metal--anywher from, say, MM Aluminum to MM Steel.   The awning fabric is a nominal white or buff color.   Agains the shiny AL finish, I'd be inclined to use Unbleached Linen or Radome Tan 50% tinted with white.
When brand new, the awning comes with a pull strap of nylon tape about 1.5" wide fastened to the hub of the winding axle of the awning to help pull the thing open.  These fastened to the arms with a snap fastener, which failed often rather quickly.  The strap would then flap against the trailer side, leaving some distinctive scuff marks.
Since the awning is jest a vinyl or vinyl-covered fabric, an individual trailer owner could replace the factory fabric with fabric in another color.
The gas bottles (almost universally Propane in the States) really ought to be white.  Mis-matched bottles are common, too.  The size you have is the 20 pound size in the US, there is a 40# & 100# size as well.  If you google image search for "RV propane tank sizes" you will get some handy reference photos.
    December 2008
Posted by PatW on Sunday, November 3, 2013 6:13 AM
Hi HeavyArty. I've raised the suspension a bit so to give it a bit more ground clearance..............................
CapnMac82, thanks for the info.
Posted by HeavyArty on Sunday, November 3, 2013 10:28 AM
Looks much better, very nice.
Posted by CapnMac82 on Sunday, November 3, 2013 9:58 PM
PatW
No sweat.  There are enough differences between "campers" and "caravans" to be worth noting.
That, and offering a chance to add color, if you wanted to, to your excellent model.
Which only really needs a station wagon loaded with camping gear to complete.
    March 2004
Posted by subfixer on Friday, November 8, 2013 8:17 AM
CapnMac82
PatW
Like this classic; "You may think you hate it now, but just wait till you drive it"
Posted by CapnMac82 on Saturday, November 9, 2013 1:19 AM
Aunt Edna?
    January 2006
Posted by dirkpitt77 on Saturday, November 9, 2013 10:01 AM
I like that! Awesome build!  Yes
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    March 2004
Posted by subfixer on Saturday, November 9, 2013 10:29 AM
CapnMac82
Aunt Edna?
Dog killer!!
Here are some shots of 1953 models.
Posted by CapnMac82 on Sunday, November 10, 2013 8:32 PM
Sparky, Cousin Eddie dropped by . . .
    December 2008
Posted by PatW on Friday, November 29, 2013 8:48 AM
I've done a couple of bits, the winder for the front stand and a plasticard box with the spare wheel supplied under the rear.....
    December 2008
Posted by PatW on Friday, December 6, 2013 10:20 AM
Well I've just finished the last few bits, Painting the tyre carrier and adding a power cable to attach to the tow vehicle......
Into  the Ikea cabinet...............
Now if you are a super detailer (which I am not) try one of these. Imagine  opening up and hinging the door, opening up the windows and adding clear plastic, Adding the floor and detailing the interior and adding the xterior awning. That would look really good!
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 10:29 AM
That's sweet. And it's unique when compared to all the cars, ships, and planes. I love unique models. Great work.
Current project(s): Hobby Boss: 1/72 F9F-2 Panther
                                  Midwest Products: Skiff(wood model)
    December 2008
Posted by PatW on Friday, December 6, 2013 10:40 AM
Thanks JimNTENN, You noticed that pretty quick! Yes it's different, that's what I like about it, but as I've put in the thread imagine what you could do if you were a super detailer!
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 2:22 PM
I love super detailing models. Of course, often times super detailing a model requires some scratch building skill if after market details are not available. I've scratch built a few small parts before but my scratch building skill is not yet where I want it to be. I hope to eventually be able to scratch build virtually anything. And, super detailing often requires good reference sources to get it accurate. However, I'm sure for a subject such as this one could use their imagination to some degree and be just as pleased with the results.
    December 2008
Posted by PatW on Friday, December 6, 2013 3:38 PM
Yes I see your point. I bought a Scamp Trailer from Star Models/Resin Realm and it had the interior included. I then bought the sundries , coffee pot, mugs,kleenex kitchen roll, waste bin, ceiling lights and microwave oven from Scale Equipment to finish it off. I also scratchbuilt a teardrop trailer from plasticard and a pair of spares box wheels and tyres.
    January 2006
Posted by SprueOne on Friday, December 6, 2013 6:41 PM
oh, that's unique Yes Very modern looking with the diamond plate material but with a retro line design
PatW
There is a Whole Foods in town and they installed one of these trailers in the food court area. It's a mini bar that they serve beer out of Cool
    December 2008
Posted by PatW on Saturday, December 7, 2013 2:21 AM
We've got a programme on prime time TV at present 'Small Spaces' where people have bought seemingly worn out vehicles and turned them into various mobile shop selling different foods from what we in the UK call caravans. But also people who have bought derelict buses, both single storey and double deckers and converted them into clothes shops, restuarants and hospitality units that drive from one sporting event to the next, be horse show, motor racing, airshow etc.
