Ok here is the farm wall with entrance im using cut out and built and used testors contour putty to fill in holes from mistakes i made while removing extra plastic on the Miniart kits.
Also with this being set in the middle east should i cover the bricks with putty and try to make them look like stucco finish?
I do have a Question for anyone reading this that might know. Do all the MiniArt kits like this one have jsut a ton of extra plastic all around the parts that you have to try and cut out ? Also i used a dremel tool to remove mine and i was wodering if there was a better way ?
