Need Comments
    May 2014
Need Comments
Posted by Nomad53 on Tuesday, June 3, 2014 4:47 PM
Here is a dio base (not finished) that I would like comment on. Please tell me what I need to do, change or add.
Nomad53
    June 2013
Posted by Viejo on Tuesday, June 3, 2014 9:10 PM
Uh, put a model on it?  It looks good, but without knowing.......
    October 2004
Posted by ygmodeler4 on Tuesday, June 3, 2014 11:29 PM
What scale is it? What are you planning to do with it? It looks good to me...but without knowing what your plans are its hard to comment.
The only evidence I have is that it's somewhere in Europe set in WWII because of the poster? The poster seems out of place there though. It breaks up the continuity but I'm thinking, why would a poster be on a wall behind the bushes in the country?
Other than that it looks pretty good, but again, if you want to get more some critiques and ways to help make it better, let us know what your planning to do with it, even if the figures or vehicles arent finished. Either way, I'm looking forward to seeing what you do with this one!
-Josiah
    December 2013
Posted by CodyJ on Wednesday, June 4, 2014 12:13 AM
Honestly I like the look of it!  I might thin out some of the small rocks. The grassy area looks perfect as-is.  Some guys use thin balsa sheets and paint them, then cover the edges to hide the foam.  Oh and the stone works look good too!  I like the damage as well!  Look forward to seeing what you are going to put on it.
    March 2014
Posted by kpnuts on Wednesday, June 4, 2014 1:07 AM
It looks good but as has been said what's it for?
    May 2009
Posted by Pawel on Wednesday, June 4, 2014 2:10 AM
Hello!
The base looks good at the first glance. But it also has things that I would do differently. First thing - the edges. Bare styrofoam doesn't look good, so it's a good idea to start with some kind of a frame (photo frames look good and are cheap), and then frame the styrofoam and dress up the portions that rise higher. You have lots of choices here - balsa, plywood, veneer, styrene plate - anything but bare styrofoam. So that's one thing and it would have to be done at the beginning of the build. At this stage it's getting much more difficult. Second thing - paint the groundwork before applying the grass. Colours ranging from dark green to black are OK. You could even take acrylic paint of dark colour as the glue for the grass, that works fine, too. What we have now is the white base shining through - not very realistic.
There's also something about those stones on the slope that bothers me - maybe there are to many of them, or maybe they look too "freshly laid down" - I guess it would help to either have fewer of them, or to cover some of them with grass to show they have been laying there for some time. I also don't understand the idea of the poster - it probably would be better to place it on a pole with a few planks attached or something like that. If you plan to show some activity on your dio, I thin you should also show the vegetaqtion worn down a little through walking, driving etc.
As I said, the looks overall are very good and I hope you keep up the good work, good luck with your projects and have a nice day
Paweł
www.vietnam.net.pl
    May 2014
Posted by Nomad53 on Wednesday, June 4, 2014 5:44 AM
I really would like to thank all of you for the comment. I will put to use what you are telling me. Yes the dio is not finished and I know I need a base which will come later. I had just got the rocks put on the dio when I took the photos and did not even think about putting the gun on it. The scale is 1/35.
After looking at the dio I can see what you are saying about the rocks looking like they have just been laid and will pit more grass and dirt over them. The poster was just to give some break up of the wall. The scene I was thinking of was a courtyard just inside of town. Maybe I did not capture that and that is my fault.
Below are photos with the gun in place.
Nomad53
Posted by Gamera on Wednesday, June 4, 2014 7:39 AM
Looks good to me! Other than what the guys have already pointed out the bushes all look the same colour to me and it's maybe just a little 'too' green. You might consider spraying them with a little dilute brownish paint just to tone them down a little, and you can add a little more to some and a little less to others to vary the tone.
    May 2014
Posted by Nomad53 on Wednesday, June 4, 2014 10:59 AM
Gamera
 Great idea.
Nomad53
    August 2005
Posted by highlanderburial on Wednesday, June 4, 2014 11:00 AM
Concur with the bushes comments. I might experiment with some green inks, and mix some black inks to try and tone them down a bit. Experiment with some foliage that ISN"T on the diorama first. I might use some dark weathering powder around the battle damage holes to tone it out.
Thanks for posting and being open for comments.
Imagine a witty signature right .....here....
    May 2014
Posted by Nomad53 on Wednesday, June 4, 2014 11:34 AM
If comments make me a better modeler the I am open for all.
Thanks,
Nomad53
    May 2014
Posted by Nomad53 on Wednesday, June 4, 2014 3:40 PM
 Okay here goes. I hope this is an improvement.
Nomad53
    April 2006
Posted by waynec on Wednesday, June 4, 2014 5:00 PM
having just airbrush painted my first base a misting of a dust or light brown color would  really tone everything down. i like the shrubs, i like the reedy grass but together isn't working for me. nor is the poster. i like the top side and the wall though i don't know if an AP or HE round would leave a mark like that in a stone wall. looks more like an armor hit and a nice one at that.
interestingly the last pic looking down at the front brings it all together. the shrubs running down the hill from the point on the wall and the stones really work in that view.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    December 2013
Posted by CodyJ on Wednesday, June 4, 2014 6:17 PM
The rocks look much better since you added vegetation and dirt  to them!  Looks good man!
    May 2014
Posted by Nomad53 on Wednesday, June 4, 2014 7:49 PM
Thanks Cody. I am trying my best to work with what I have at hand.
Nomad53
    May 2014
Posted by Nomad53 on Wednesday, June 4, 2014 8:25 PM
Okay here it is. Done except for the base.
Nomad53
Posted by Gamera on Thursday, June 5, 2014 1:08 PM
Hey Nomad, looks really good! The brown toned down the green a little and brought everything together.
Only thing I'd bring up now is the 'feet' or whatever you call them on the legs of the gun were dug in so when it fired it wouldn't jump back and slam into the guys. You might want to just chip away a little of the groundwork there and shove the ends of the legs into it and then build up a little groundwork behind it.
Just nitpicking though- very nice work! I'm glad I don't have photos of my first diorama- you guys would laugh me right off this forum!
    May 2009
Posted by Pawel on Thursday, June 5, 2014 2:29 PM
Hello!
Those are called trails. Our redleg brothers would have to verify it, but I guess a few sandbags also could help secure the spades in place. That's an important detail. It would also be a good idea to put some dirt on the boots of the soldiers - to show they've been there done that for a while. Good luck with your dio and have a nice day
Paweł
www.vietnam.net.pl
    May 2014
Posted by Nomad53 on Thursday, June 5, 2014 2:39 PM
Thanks all. Pawel you are right they are called trails. I was in an arty unit back in the day. 105's. I will work on them and get them dug in. It was late in the night when I got done and just forgot to do that.
Nomad53
    April 2006
Posted by waynec on Thursday, June 5, 2014 7:26 PM
Gamera
they would be the gun trails. you can gouge out a bit to set them in the ground or add a little modeling clay to build up a smal moung and cover it with your brown ground turf. painting the styrofoam edge helped a lot too.
    March 2007
Posted by armornut on Friday, June 6, 2014 9:46 PM
Really nice, in the first string of pix the one looking down the tube it looks like the hole in the muzzle brake didn't quite match, not a deal breaker by any strech just a helpful observation, maybe my eyes are crossed  the weathering on the gun is awesome. Ground work is tough to do if your just starting but you have a handle on it. Great work!
we're modelers it's what we do
    January 2005
Posted by daveinthehat on Saturday, June 7, 2014 7:04 PM
Your diorama looks better with the improvements that you made. The look of the wall could be improved with a dusting of pastel, chalk or weathering powders to vary the colors of the stones a little more and highlight the mortar.
I glue my dioramas to a piece of MDF. It gives them more support since I move them around a lot.
    August 2010
Posted by Ghostrider114 on Sunday, June 8, 2014 2:21 AM
My only suggestion is to break up the sides of the wall a little bit.  Rock walls rarely break smoothly.  the mortar is going to break before the stones.
    September 2007
Posted by SuppressionFire on Sunday, June 8, 2014 6:14 AM
Familiar 75mm AT gun by Tamiya & crew!
Liking the progression of your display. The AT gun in a defensive roll was most effective camouflaged. A few bushes on the top side - think Normandy hedge and a camouflage net over the gun, leave the gun sight clear to view.
A few more tweaks and call it complete. Look at other modellers work and always check reference photographs. Your next project will always be better!
One more thing to consider changing: The 75mm shells leaning on the ammunition box would not rest at a angle like that, the would roll off. A lot of modellers place the shells on the ground resting on a tarp.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    May 2014
Posted by Nomad53 on Sunday, June 8, 2014 10:10 AM
This is why I like these forums so much. All the helpful tips and suggestions. I will make all the changes that have been suggested and post pics when done.It may take a while but it will get done.
The shells had moved when the photos were taken. They are not leaning now. LOL
Nomad53
    August 2010
Posted by Ghostrider114 on Monday, June 9, 2014 12:43 AM
SuppressionFire
True, I've found that one of the hardest things to do in a scale model diorama is make things that are supposed to be heavy sit so that they look heavy.
    June 2014
Posted by minitnkr on Tuesday, June 10, 2014 11:03 AM
Suggestions to bring the courtyard into the city. Add pieces of wrought iron fence or simulated broken glass (cut up cellophane tape works) to the top of the stone wall and some garbage caught in the rocks/bushes. Very nice first effort. Paul
    May 2014
Posted by Nomad53 on Wednesday, June 11, 2014 8:47 AM
Looks like I'm going to have to sit back and take all of this in. What I need to do is collect my thoughts and start really looking into the subject matter and do some research. All these ideas are really great, I just wish I had the years if experience to pull it off. I have found that I am never to old to learn something. You all are great.
Thanks,
Nomad53
    August 2010
Posted by Ghostrider114 on Wednesday, June 11, 2014 12:31 PM
I know how that feels, since I got back into models a couple years ago, I've found that my mantra has become "Research, Research, Research."
Posted by CapnMac82 on Wednesday, June 11, 2014 4:46 PM
The rocks have improved--but, I was willing to accept it was a verdant springtime before.
Getting some brown down before the green is one of those subtle things for vegetation.
You might want to consider changing to a 75mm howitzer, or an 81mm mortar, as the gunner on that PAK is not going to like that wall in front of his front sight.
AT gunners like to have an "alley" to shoot along, preferably downhill.  Now, your dio could be of a location at the bottom of a long down slope.  In which case the gun crew would have tarps & netting rigged to stay out of view.  They'd also dig a pit to get the breech of the gun lower to the ground, too.
