Thanks Nomad. I have been building 72nd aircraft for a long time so its pretty normal to me. And there are plenty smaller than this.
Now that's a question. I will try and explain as best I can, I am not very good at that sort of thing. I use something called paint.net, its free to download and I use it for my GB badges. It took me quite some time to get used to using it properly, but then computers are not my forte.
I open a new project selecting the size I want, although for some reason the print size I put in is not the same as it comes out. I then just add the first flag, which has already been shrunk, then the text and then the other image. After that I save it to my comp and then put it into a word doc so I can get it to the size I want, then print off on card.
That's probably not very helpful and easy to understand, but that the best explanation I can give. This is the download if you want to check it out.
www.free-4-pc.com/.../Paint.NET
It has all sorts of tutorials and stuff on there.
I only started using these name plates last year. before than I used rub off letters, but these were a real pain.
