Resin building kit help
    February 2014
Posted by Caddyshack on Tuesday, October 4, 2016 9:49 AM
I purchases two resin building ruin kits at a show this past weekend.  I've never worked with resin before.  Pretty much the only directions for assembly are the images on the box.  What is the recommended glue for these types of kits?
This crowd has gone deathly silent, the Cinderella story, outta no where, a former greenskeeper now - about to become the Masters champion. It looks like a mirac - It's in the Hole!
Posted by HeavyArty on Tuesday, October 4, 2016 11:04 AM
I prefer to use super glue (cyanoacrylate).  You can also use two-part epoxy.  Regular model glues will not adhere to resin.
    July 2003
Posted by ridleusmc on Tuesday, October 11, 2016 2:14 AM
Cutting and sanding resin produces a fine dust which is harmful to your respiratory system.  If you're working resin, you should cut and sand while wearing a respirator or dust mask.
    August 2005
Posted by EdGrune on Tuesday, October 11, 2016 2:10 PM
Wet sanding using hardware store type wet/dry sandpaper will help keep the dust down. I attach a piece of wet/dry to a sheet of plexiglass with contact cement and sand at the kitchen sink. This facilitates straight and flat gluing surfaces. Sand in a circular or figure-8 motion and swap hand positions to help maintain even sanding pressure
Posted by Bish on Tuesday, October 11, 2016 2:26 PM
I use CA glue for resin as well. Just make sure you test fit, once its glue, it can be a real pain to un stick it.
If there are any thin pieces, handle with care as they can be brittle.
    September 2012
Posted by GMorrison on Wednesday, October 12, 2016 1:36 AM
Or epoxy. Nothing else works nearly as well.
    February 2014
Posted by Caddyshack on Wednesday, October 12, 2016 12:59 PM
Thanks for the suggestions.  I think I'm going to try a 5 minute 2 part epoxy
    June 2014
Posted by Tanker - Builder on Sunday, November 13, 2016 12:43 PM
Hi;
   Having done this at the R.R. Museum , definitely go the epoxy route ! .
