Questions about FOAM and Foam Cutters
Posted by Anonymous on Saturday, April 10, 2004 11:40 PM
I was visiting a fantasy hobby store today and saw some foam that was used as a base for some figures, it was painted and looked really cool, wasn't styrofoam but something more dense and was cut using a hot wire cutter. Do any of you use this type of foam and if you do, what is it called and where the heck can you get itTongue [:P]. Where would be a good place to get the hot wire foam cutters and is there anything else you would recomend?
Thanks
    October 2003
Posted by rebelreenactor on Sunday, April 11, 2004 12:53 AM
I'm not sure what kind of foam it is, but If there is a Michaels near your home/city they are bound to have a foam cutter. that's where i got mine. It was in the styrafoam department. If they don't have a Michaels near you then just check out a local craft store.
www.michaels.com is the web address.
John
Posted by Anonymous on Sunday, April 11, 2004 8:11 AM
It was probably expanded polystyrene. The hot wire thing is called a "thermal saw".
The material is great for creating height curves or wall structures. It is also available sandwiched between two thin sheets of cardboard. This is what I mostly use. I get it from an art supply store. Thicker (approx. 3cm) sections are also used as insulation material I believe.
You can cut it with a thermal saw but a hobby knife works well also.
Posted by Anonymous on Sunday, April 11, 2004 10:12 AM
miller41,
I did a google search on foam cutters and came up with quite a few items on the hot wire cutters. Regarding the foam, I use the foam that comes in 4'x8' x2" sheets for house insulation and is sold at the local building supply store. It cuts well with a hot wire knife and can be used for quite a few things in diorama buildingCool [8D] It is denser than styrafoam and guite ruggedBig Smile [:D]
Richard
Posted by Anonymous on Sunday, April 11, 2004 5:10 PM
thats what I was looking for, I found out today that is called expanding Polystyrene and I can buy it here.
