diorama bases
diorama bases
Posted by Anonymous on Wednesday, April 21, 2004 4:44 PM
How or where can you get diorama bases. Do any of you smart people out there build them yourself? Can you purchase them all ready built?
Thank you
seakinght
Question [?]Question [?]
Posted by Anonymous on Wednesday, April 21, 2004 4:52 PM
You can buy them built already. Look at craft shops like Tall Mouse, Michaels, or maybe Wal-Mart. If you look through the FSM magazine at the advertisements there are a few for bases and cases.
    October 2003
Posted by rebelreenactor on Wednesday, April 21, 2004 10:25 PM
I have used a 2x4but it didn't look to good. If you routered the edges then it would probably look pretty good. For the most part i use plaques, First stain the plaque or leave it unfinished. then seal it with a varnish. Next mask the edges so no paint or celluclay or something gets on it and ruins it. Then build your base.
Ifyou wantto by a plaque try a craftstore or Walmart.
is thiswhat you were asking? Letme know if it was or not, i'll try to help some more.
John
    April 2004
Posted by BigDuke634 on Wednesday, April 21, 2004 10:34 PM
Check out thrift stores like Goodwill too I find a few there.
Posted by Anonymous on Wednesday, April 21, 2004 10:39 PM
By the way, Sign - Welcome [#welcome]
Posted by Anonymous on Thursday, April 22, 2004 10:41 AM
Sign - Welcome [#welcome]seakinght I like others use plaques and i also use picture frames
get some cheep ones and try it and have fun.
Posted by Anonymous on Thursday, April 22, 2004 1:15 PM
Welcome aboard seaknight Smile [:)]
I use ceramic tiles, you can get them cheap at most hardware stores. They make a nice firm base for whatever you want to put on your diorama and short of dropping them it's pretty hard to damage them through the building process.
Posted by Anonymous on Tuesday, April 27, 2004 1:03 PM
Thank you all,
rebelreenactor, scubaboy99, BigDuke634, jimq, wrbridge. You helped me significantly
seakinght
Posted by Anonymous on Friday, April 30, 2004 2:22 PM
Pirate [oX)] I have had a lot of luck with 12"x12" cork squages and ceiling tiles, both or light and take adhestive well. Next in line is 1/2" or 3/4" plywood cut to size then edged with one of the fancy strip moldings that are availabe at most lumber stores. Good Luck and get me a jiggle if I can help futher. OldDog
    July 2003
Posted by KJ200 on Thursday, May 6, 2004 7:05 AM
I use 1/2" MDF, mainly because I several sheets of it in my garage, a present from the previous owner of my house.
This works fine for me as it is east to cut, especially with a jig-saw, and unlike ply, is reasonably weighty which means models displayed on it are less likely to be knocked off by careless dusting!!!!
I just edge it using lengths of panel moulding available from hardware stores, cut on a mitre block.
This works out real cheap.
Karl
Posted by Anonymous on Saturday, May 8, 2004 10:35 AM
I use Foam when I make my diorama bases and then line the out-side with some nice wood. Then foam is nice because you can easly make fox holes and track marks with a heat gun or something that is hot.
Posted by Anonymous on Saturday, May 8, 2004 2:05 PM
Hi seaknight,
First off, welcome Sign - Welcome [#welcome]
The base I am building will consnst of sheet rock (wall board) to replicate an airfield ramp and the area off the ramp will be the type of sheet foam used as insulation in homes for the grass/dirt area. The outside perimeter will be stained oakApprove [^]
As far as buying them they gave you good data and you can also use on line hobby stores such as greatmodels.comCool [8D]
Good luckBig Smile [:D]
Richard
    July 2003
Posted by Dwight Ta-ala on Tuesday, May 11, 2004 1:53 AM
Try chopping boards. I have used them in my dios. Pretty cheap, too.
