sidewalk techniqeus
sidewalk techniqeus
Posted by Anonymous on Tuesday, October 12, 2004 10:43 AM
how to make an American looking sidewalk?
all i could find sofar was the Busch "European look"sidewalk with the small cobble stones.
anyone would share the techniqeus of making those with an American look?
i hope you understand my poor english,please ask if i didn't make it clear to understandShy [8)]
thank you,
hans
Posted by renarts on Tuesday, October 12, 2004 4:47 PM
Hans,
American sidewalks are large square or rectangular forms as they are poured rather than built from cobblestones.
What period are you interested in?
Posted by Anonymous on Wednesday, October 13, 2004 7:57 AM
Mike,
i'd say modern although a time period is not really that important to me .
actually i'm trying to figure out how i can make a concrete look-a-like sidewalk.
plaster would be too thin and will probably break when the relief is put in or when i sand it down to the right height..
painting is no option B/C i can't make relief in it then.
hans
Posted by renarts on Wednesday, October 13, 2004 5:08 PM
Modern sidewalks are poured squares or rectangles. Even the longer continuous paths are "scored" or cut to relieve stress to compensate for ground movement and temperature changes as well as contain damage to smaller areas.
If you are including road or grass with your sidewalk, you could lay your base and use something like styrene, card stock or very thin door skin or wood to raise up your sidewalk elevation from the road or grass. This can be covered with spackle, wall compound, modeling paste, or plaster and as it starts to dry a piece of fine sandpaper can be impressed to give it the texture of concrete. Sress lines can be scored with a knife or as it is setting up, a brass shim can be used to "knife" in the slab edges. By gently rocking it back and forth a little it will bevel the edges slightly and once it is painted and given a wash, they will stand out nicely. If you want to paint the sidewalk, you could do the same by using cardstock to make your slabs and then paint it with a textured paint (using fine sand, or baking soda similar to what is used to make rust on armor exhaust) for texture.
If I am doing concrete I usually paint it a light grey, stipple it with a dark grey and stipple it with white over that. This makes a very nice concrete looking finish.
Posted by Anonymous on Friday, October 15, 2004 12:51 AM
Thanks for your suggestions.
i've decided to give it a shot with the first idea that came to mind.
i've did the following and it seemed to work well although i wasn't so sure in the beginning.
i poured a very thin 2-3 mm plaster layer with fly curtain in it for to stronger it.
(looks like armed/waponed concrete)
colored the plaster with black water based folkart paint in to gray.
cut the squares with an x-acto knife.
some pieces didn't work out to perfectly but still i do use them and let grow some grass and weeds in the spaces inbetween it.
to be continued
Hans
Posted by Anonymous on Saturday, October 16, 2004 8:45 AM
thanks again guys.
finished the sidewalk today and this is what it became.
have fun!
hans
http://albums.photo.epson.com/j/ViewPhoto?u=4159018&a=31071560&p=69799097
