can anyone help
    October 2004
can anyone help
Posted by shroomy on Wednesday, October 27, 2004 9:40 AM
hi everyone another of these born again kids lol
i am trying to recreate corrugated tin roofing in 1/35 scale can anybody help me please
Posted by ajlafleche on Wednesday, October 27, 2004 12:57 PM
Historical Miniatures #45 has an article aboout a scene from Mogadishu wherein the author describes this. You can get this magazine from http://www.sentinelminiatures.com or http://www.redlancers.com
    September 2003
Posted by dpty_dawg_ca on Wednesday, October 27, 2004 8:15 PM
Model Builders Supply in Aurora Ontario has a line of textured sheet styrene that includes corrogated roofing.
http://www.modelbuilderssupply.com/
My probblem is that I haven't found any paint scheme yet that will reproduced galvanized steel.
Carl
    July 2004
  • From: ...Ask the other guy, he's got me zeroed-in...
Posted by gringe88 on Thursday, October 28, 2004 4:55 PM
evergreen styrene carries sheets of the stuff in varying thicknesses.
here's their site:
http://www.evergreenscalemodels.com/
hope it helps....
====================================== -Matt
    October 2004
Posted by shroomy on Wednesday, November 3, 2004 11:34 PM
thanks for your help chaps :)
Posted by Anonymous on Thursday, November 4, 2004 10:09 AM
QUOTE: Model Builders Supply in Aurora Ontario has a line of textured sheet styrene that includes corrogated roofing.
The main drawbacks of the Evergreen sheets are their thickness and lack of detail on the "in" side. If it was up to me, I'd get some corrugated Evergreen sheet and use two sheets faced together as a press to emboss pieces of thin sheet metal (I'd probably use the heaviest gauge aluminum foil I could find) cut to the scale size of a standard hunk of tin (I want to say 3'x6', but I'm probably wrong, google it!). That way, PCB etchant could be used to weather the material if desired.
I've had pretty good luck (IMHO) replicating the color of galvanized sheet material with the cheapest store-brand gray primer I can find. Weather it up and you're GTG.
    July 2003
Posted by zokissima on Thursday, November 4, 2004 11:08 AM
Sign - Welcome [#welcome] to the FSM forum, and to the hobby Smile [:)]
There are a variety of products, as mentioned above. However, one other, cheap, method might be in order as well. Take some normal corrugated cardboard, and remove one of the top layers so that you can see the corrugations. Paint it thickly with white school glue, and allow to dry. You do this so that the cardboard will become harder. Then, take some thick aluminum foil, and pressit onto the cardboard, being careful not to collapse any of the bridges. Once done, you'll have a nice print to use.
If memory serves me right, a similar technique was used by one of the authors of TMMI for a diorama, and the effect was done very well. I'll see if I can dig up the mag for some details.
