1/35 Figures
1/35 Figures
Posted by cmixson on Thursday, November 25, 2004 10:26 PM
I was just wondering how some of you guys make some of the figures that you use in dioramas. I can find figures in different poses but how do you change these poses to fit your schemes?
I have a Long Tom and an 8 inch howitzer that I would like to use some figures around. Other that buying an expensive set just for the purpose is there a way to convert some of the Tamiya or other kits? Any ideas will be welcome.
Thanks,
Carroll Mixson
Currently on bench: Minicraft/Hasegawa 1/72  A6A Intruder
http://www.flickr.com/photos/9310736@N02/
    July 2004
  • From: ...Ask the other guy, he's got me zeroed-in...
Posted by gringe88 on Friday, November 26, 2004 9:57 AM
well, you can start by getting some figures relative to what you're building, like U.S. WWII artillery men in this case. also look around for those that have interesting or similar poses to ones you are thinking of. even if they're not of the same unit, you can convert them.
to convert figs, use a razor saw to start cutting apart the various body parts. you need to reshape them for what you need. for example, cut an arm in half at the elbow joint. when you're cutting think of how the arms going to be bent. you can try cutting a wedge out to help bend the arm more. or just sand the ends of the bisected arm at the correct angles, to make the arm bend the way you want it. then simply reglue the ends where they join. but, if you're trying to straighten out the arm, or just bend it, dont try to fill up the whole gap you made with glue. glue the parts where they meet, and later, once they're dry come bakc and ust some putty to reform the missing or misshapen areas. you can use putty on other areas as well, like to reform or give a new shape to parts, without having to cut them, like adding pockets, or reshape a figurews neck to make it look like he's turning his head. you can cut off the hands, and drill out the ends of the arms, and then reglue the hands back on, to make it look like the figure is wearing a separate coat.
other people can probably add some more. they'll be along don't worry.
hope it helps!
====================================== -Matt
    August 2003
Posted by chevit2001 on Saturday, November 27, 2004 8:23 PM
if they are still available may want to obtain the books "How to Build Dioramas" put out by Fine Scale Modeler. There are two editions I think. They both have articles on posing and painting figures. Also the book "The Art of the Diorama" by Ray Anderson. It has an article on figure conversion and posing and detailing plastic figures. Then there is the book :Conversion and Scratch Building of Model Figures" "A Series of Modeling Manuals" put out by Andrea Press. There are other scale modeling books out there on modeling figures. I love the availability of 1/35 scale figures. I use them to help liven up my various other models. I don't model military much so I have to convert them which is fun and challenging. Hope this helps!!
Posted by cmixson on Monday, November 29, 2004 10:48 AM
Thanks for the ideas guys! I will start putting them to good use.
