Water
Water
Posted by Anonymous on Tuesday, November 30, 2004 10:51 AM
Hi modellers,
I want to make a diorama w/ Tamiya's "Pibber". So if somebody tell me how to make the waves. Cool [8D]
Posted by HeavyArty on Tuesday, November 30, 2004 11:23 AM
There are quite a few ways to make water. Here are a couple.
1. Fiberglass resin: Use fiberglass resin for fiberglass repair. It comes in a two part compound where you add the hardener to the liquid resin. It can be found in the auto repair section at Wal-Mart or the like. You can only pour thin layers, about 1/8 - 1/4 inch at a time. Be carefull, it does heat up and will dissolve some paints. It also shrinks slightly when cured. You can tint the water by adding in paint to the resin before you pour it as well. Also, by varying the color of the layers, you can add the look of depth. This is the method I prefer. Here is an example.
To represent the wake, I use 5-minute epoxy built up behind the boat in a wake. Either leave it untinted or add some white to it for the foam and froth.
2. Tinted glass. Another option is to use tinted glass. This allows something under the waterline to be seen. It is best for flat, smooth water. The glass can be tinted with stained glass paint. It is transparent and is used to paint on glass or plastic to represent stained glass. You can aslo get glass that has some texture to represent small waves. Here is an example of this method.
3. Plaster or Celluclay (Paper Mache). You can aslo form the water in plaster or paper mache and paint it as water. To give it the illusion of depth, coat with many thick layers of gloss lacquer or shilac once done. Sorry, no examples. Many ship builders use this method to represent the sea in large areas for ship dios.
    May 2004
Posted by madspaniard on Tuesday, November 30, 2004 3:22 PM
I use the material to fill walls,give the texture and the right painting job like bellow
Happy modelling
Pedro
Fw 190 A-3 Richtofen JG
    August 2004
Posted by unclesnap on Tuesday, November 30, 2004 5:20 PM
hello comando, finescale back in march 2004 ran Diorama / How-To "Modeling Water" with EnviroTex and using NON-STICK Reynolds Wrap. thats what i used on "Now, Then, Forever" My First Dio. you might want to check-it out and see if that's what your looking for.
Posted by Anonymous on Tuesday, November 30, 2004 5:51 PM
You can also use acrylic gel, or a medium called EZ-water.
Again pour in thin layers.
Personally, I am not too fond of coloring the "water" directly but rather color the base, this way the water has a transparency when viewed from the side and also show detail below the waterline clearly. Plus, I think it will look more realistic for clear natural water.
For muddy river water basically any medium that can be painted/textured will do.
Posted by Model Maniac on Wednesday, December 1, 2004 2:53 AM
My modeler used clear resin to simulate water and waves. To make the waves, while the resin has not set or dried, he put a stick into the resin and stirred and levered it to make it look like waves. Here's what he came up with :
ps. more pics of this "VC River" diorama available at :
http://www.falconbbs.com/model10.htm Smile [:)]
Impressive Songs:
All 10 Playlists that I created on Youtube:
http://www.youtube.com/user/ModelManiacThailand/playlists
Pan Flute Music (300 songs) (Most Popular, over 100K views):
https://www.youtube.com/playlist?list=PLUNb2zPxGTZO7alagEPsEMzgBkWt4-vKV
El Condor Pasa (Top 50) (World's most famous and my most favorite song):
http://www.youtube.com/playlist?list=PLUNb2zPxGTZOLKHbju350mLle4HkMhsb8
