- Member since
July 2003
Posted by zokissima
on Friday, December 17, 2004 6:42 AM
You can use the model itself. As John said, just press the tank into the groundwork while still wet. To eliminate any material sticking to the tank, take some seran wrap (clear, plastic wrap) and lay it gently on the groundwork, then press the model into the groundwork over the wrap. You can remove the tank, but leave the plastic until the ground material begins to cure. Remove it gently, and you should have a nice imprint of your treads.
