Scratchbuilt House Ruin Project
Posted by Kelly_Zak on Friday, December 31, 2004 10:16 AM
Hi Everybody,
Been working on this for a few weeks now, with quite a bit still to do. Main materials are balsa wood and good ol' plaster. I've since added nail holes in the floorboards, and roof work has started.
Comments welcome! Smile [:)]
"There you go with those negative waves again!"
Posted by Anonymous on Friday, December 31, 2004 11:13 AM
Wow that looks awesome.
Post pics when you're done!
    November 2004
Posted by sasd on Friday, December 31, 2004 10:19 PM
One awesome piece of scratchbuilding Kelly,can`t wait to see it incerted into the dio,
gonna be somethin to see!
"Battleing Bastards of Bastogne"
Posted by Anonymous on Saturday, January 1, 2005 12:50 AM
You did a great job on the bricks - Are those walls too thick or were they really that thick back then
    September 2011
Posted by fightnjoe on Saturday, January 1, 2005 12:52 AM
wow incredible.
joe
Veterans,
Thank You For Your Sacrifices,
Never To Be Forgotten
Where you can find me:
Workbench on FaceBook  Google Plus  YouTube
Posted by Anonymous on Saturday, January 1, 2005 3:16 AM
Looks very good,i'm wondering what you'll use for the debris.
    November 2004
Posted by sasd on Saturday, January 1, 2005 8:01 AM
I have pics of ruins with walls much thicker than Kelly`s walls,the debris must have been phenominal!
    September 2004
Posted by mm23t on Saturday, January 1, 2005 1:50 PM
Looking good. Better hurry and finish it before it falls downLaugh [(-D] Looking forward to seeing it when it's completed.
Medals are not "Won", they are "Earned".
Mike..
Posted by Kelly_Zak on Tuesday, January 4, 2005 4:39 PM
Thanks for the comments gang, well the roof is all shingled and painted, windows have frames in them, all that's needed is some broken glass, and some portraits for the inside. I've set it asided for now, and resuming work on the StuG IIIG and the Krupp Protze kits that will be going into the dio.
    December 2003
Posted by buff on Tuesday, January 4, 2005 5:01 PM
What did you use for the bricks? Thanks.
On the bench: 1/32 Spit IXc
Posted by Kelly_Zak on Wednesday, January 5, 2005 9:05 AM
Hi Buff,
I actually did a "reverse" plan for making the bricks...I just drew out the areas where the plaster would be broken and bricks be exposed, and took a flat blade knife and gouged out the section, leaving about 1mm depth to the main surface. Once done, I simply took the back edge of my scalpel and just scribed the bricks in. Hope this helps!
    December 2003
Posted by buff on Thursday, January 6, 2005 2:55 PM
It sure does. Thanks for the tip!
Posted by Anonymous on Thursday, January 6, 2005 5:08 PM
One more tip on the plaster, there is a certain point in time while plaster is drying that it is easiest to work with. I call it the happy hour. During this happy hour plaster will carve and scribe nicely. After this time the plaster gets completely hard and then carving get tough. And if you try to work before the happy hour the plaster is too soft and mushy. Looks great and good job.
Posted by Anonymous on Thursday, January 6, 2005 5:22 PM
another technique I have used is to sculpt the details in the plaster nice and crisp and let it set completley. Once it is dry, use a stiff bristle brush with future and scrub the plaster. it will soften the edges and soak into the plaster making a hard finish. Go light, because it will soften the plaster and wear it down fast.
Posted by Anonymous on Thursday, January 6, 2005 5:33 PM
Tip for making shattered glass.
Cut thin plastic sheeting(clear) to the desired size, surround with dry-ice for a bit.
Than hit the pane with a hammer, voila perfect shattered window pane.
HTH.
Posted by Anonymous on Saturday, January 8, 2005 3:15 PM
Nice job. I have started scratchbuilding myself......walls, roads, fences. It is quite fun and makes the dio that much more "yours." You have inspired me to start tackling buildings.
Cheers!
Posted by Kelly_Zak on Monday, January 10, 2005 9:21 AM
Model Museum, that's a cool tip for the glass! I've been using the overhead projector foils as my glass, it's stiff enough to get the jagged edges when I cut it with my blade. Then I take my tweezers and put white glue on the ends, and glue it to the window frame.
    April 2004
Posted by yw18mc on Tuesday, January 11, 2005 2:10 AM
I envy anyone who has the skills to scratch build. Your project is very impressive. I hope that you will perodically post progress pics. Semper Fi, mike
mike
