Russ:
Really great finish & all the junk really looks natural. Great job !!!!
Nice simply stated but effective diorama !!!
I assume that is the Tamiya Lee; was the M31 conversion an aftermarket kit or did you scratch-build it all ?
Couple of technical points.
-- The side door hinges were removed & the doors welded onto the hull. The left side door had the vision port removed (blocked by the winch & cabinets); the right door retained the vision port.
-- I believe the M31 should have a 5-spoke road wheel; yours appear to be 6-spoke?
And one "operational":
-- I don't think the duffel/sleeping bag would be stored up under the dummy 75mm gun in that way as it would(could) block the door from opening.
Great work, attention to detail in all the outside storage is just great !!!!
