Help how can i make sandbags
Posted by Anonymous on Thursday, January 13, 2005 2:28 PM
I need sandbags for I diorama I am building can any help meQuestion [?]
Posted by Anonymous on Thursday, January 13, 2005 2:54 PM
Heyho, very admirable name by the way and welsome to FSM!
It seems your dilemma has an easy solution. I find the best sand bags are made just from plasticine or blu-tack shaped the way you wanted, laid and then coated in a layer of undiluted PVA (white) glue. Then paint and weather them. For a slightly more authentic touch, press the fibres of a suitable fabric into the plasticine before you coat it.
Hope I've helped,
Seb
Posted by Anonymous on Thursday, January 13, 2005 3:40 PM
try tea bags....empty the tea out and fill with sand....then sew shut again
Posted by djmodels1999 on Thursday, January 13, 2005 4:53 PM
I do as Seb said, but I use Milliput epoxy putty, first rolled into a long 'saussage' then cut into 'bags', each slightly flattened out with an old t-shirt (to give them a fabric 'feel'), then put into place (helped by the t-shirt to avoid fingerprints!). Let them dry out, then remove them from the model or diorama for painting. Then use PVA glue to put them back where they go!
    February 2004
Posted by LemonJello on Thursday, January 13, 2005 5:21 PM
I've made some with tissue paper (not facial tissue, but the kind that is used in gift boxes) and model railroad ballast. Fill them up, tie off the other end and when you have enough, dip them in a paint/dilluted glue mixture and set in place. They looked pretty good to me. I'll have to take some pics and post the Stuart I've added some to as frontal armor so you can see what I'm talking about.
A day in the Corps is like a day on the farm; every meal is a banquet, every paycheck a fortune, every formation a parade... The Marine Corps is a department of the Navy? Yeah...The Men's Department.
Posted by Anonymous on Thursday, January 13, 2005 9:06 PM
Thanks for your suggestions. They will come in handy.
Posted by Anonymous on Thursday, January 13, 2005 9:36 PM
I have found that using MILLIPUT and rolling it in between your fingers into a long round shape. Then cut to the length you want , it looks really good!!!
Posted by Anonymous on Friday, January 14, 2005 5:33 AM
Another way is to use Chiclets chewing gum! Soak it in water to remove the hard outer stuff, then mold it onto a vehicle or base. Its just the right size for 1/35 scale, but paint it quickly or it will attract flies.This sounds weird but it works (allegedly)
    October 2004
Posted by shroomy on Friday, January 14, 2005 5:50 AM
this might help it did me :)
http://www.armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=116
Posted by Anonymous on Friday, January 14, 2005 6:19 AM
Just so there aren't any misconceptions, remember Milliput is time curing, it will set underwater.
Seb
    July 2003
Posted by zokissima on Friday, January 14, 2005 6:40 AM
Shroomy beat me to it, I was gonna post the same thing Big Smile [:D]
Try the milliput method. It's a time tested and proven way to go about it, it won't cost you that much, and the results are great.
    October 2004
Posted by shroomy on Friday, January 14, 2005 9:27 AM
lol sorry zokissima
