Pavehawk dio
Pavehawk dio
Posted by Anonymous on Sunday, January 16, 2005 6:30 PM
Hi over there from SpainBig Smile [:D]Big Smile [:D].
this summer i bought the MRC 1/35 Pavehawk kit and since then i've been looking for updates kit, pilots, etc, but i haven't finished with my idea of the dio, maybe some of you have ideasQuestion [?].
i was thinking of showing the hawk hovering (still haven't decided how to do it) above a seal team which are going to be picked up on board. They're in the water and one of them is just 50 cms above the surface[:0], holded to the jungle penetrator. The questions are:
1.- how to put the hawk hovering above the water?
2.- in what possition to put the jungle penetrator, in the water? in the air with the seal? without the seal?...
3.- as the rotor surface is very big and the seals are just below the chopper, what to put in the empty areas of the water?
any help will be lovedTongue [:P]
Chopper
    February 2004
Posted by LemonJello on Sunday, January 16, 2005 6:52 PM
Too ambitious for me, hopefully someone else here has some ideas to help you out. I think the rotor wash effect on the water would be enough of a challenge without trying to figure out the rest.
A day in the Corps is like a day on the farm; every meal is a banquet, every paycheck a fortune, every formation a parade... The Marine Corps is a department of the Navy? Yeah...The Men's Department.
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Sunday, January 16, 2005 7:37 PM
Pedro,
Cool idea! For the rotors, have you thought about clear acetate with a mist of black sprayed to give a blurred rotor effect? Like LemonJello says, the water will be the tricky part.
There was some talk on the forum a while ago by people who were doing Blackhawk Down dioramas and there were some innovative ideas as to how to make the bird hover. Best idea seemed to be to use the fast ropes to hide a rod to support the model. Not sure how you'd do that with a PaveHawk, since the line on the winch is so much thinner.
Hope that helps some.
"1-6 is in hot"
Posted by Anonymous on Sunday, January 16, 2005 9:01 PM
try putting a magnet in the base of the dio and put a magnet in the pavehawk. the way this works is you get 2 north magnets or 2 south magnets and they repel each other. I learnt that in sicence class
    February 2004
Posted by Trigger on Sunday, January 16, 2005 9:29 PM
Don't worry about the "negative space" on the water's surface where the SEAL's aren't. The main rotor downwash effect will activate that area plenty and could actually help the viewer focus in on the SEALs
http://www.af.mil/photos/factsheet_photos.asp?fsID=107
http://www.globalsecurity.org/military/systems/aircraft/images/hh-60g-DF-ST-98-04892.jpg
http://www.globalsecurity.org/military/systems/aircraft/images/hh-60h-Kduck.jpg
------------------------------------------------------------------ - Grant "Can't let that nest in there..."
Posted by Cobrahistorian on Sunday, January 16, 2005 10:52 PM
superconductors. Use superconductors.
"1-6 is in hot"
Posted by Anonymous on Monday, January 17, 2005 9:36 AM
Big Smile [:D]thank you very much for all the repliesBig Smile [:D], i have took notes from them. Model Lover, do you really thinks that your way of hovering the hawk could work? if it does, it will be the most realistic way to do it, but it should be safe. I dont want to leave the hawk 5 cm above the floor and crashed the next second. Black Eye [B)]
do some of you have tried that experience??!!Blush [:I]
hope to receive new ideas and replies, still lot of work to think aboutApprove [^]
thanks againWink [;)]
Pedro
Posted by Anonymous on Monday, January 17, 2005 10:00 AM
what you could do i have a backround, and attach a roto blade too it.
i once seen a video of a seal team in a raft drive right up into the back of a hoverering chinnok. i don't know where it is though.
Posted by Anonymous on Monday, January 17, 2005 7:25 PM
i dont actually know how safe it is im sorry
Posted by Anonymous on Monday, January 17, 2005 7:32 PM
if you put it on magnets use the winch as a anchor...... just a thought!!
there was a FSM issue were they showed how to make water with a scene with the astrounts and they had rotor wash there.....idk which one it was...
great idea for a dio!!!
    March 2004
Posted by DanCooper on Tuesday, January 18, 2005 5:28 PM
I think a 1/35 Pavehawk is way too heavy to use magnets, ofcourse I can be wrong.
However, if it works (and that is a very big IF), than you will need more than one anchor to keep the heli in place, because if it shifts too far off the center of the magnetisme, it will crash.
Have look at those lilttle Revell kits (the jets are 1/144 and the prop planes are 1/72), those have 3 or 4 anchors coming together at the plane.
By the way ; you do know there is a hawk groupbuild going ?
On the bench : Revell's 1/125 RV Calypso
Posted by Anonymous on Tuesday, January 18, 2005 7:07 PM
First of all, A BIG THANKS TO ALL OF YOU FOR READING MY POST AND TRYING TO APPORT A SOLUTIONBig Smile [:D]Big Smile [:D]Big Smile [:D]
Yes, i'm totally agree with you DanBig Smile [:D]. I think that the magnetic field would be very difficult solution to keep a bird of that weightSad [:(]. And with the anchors, if i put too many anchors, the hawk would seem and oil rig tighted to the seabed instead a flying machine, don't you think so? I'm considering the posibility of hiding a steel bar as a support somewhere but...where can i attached it if we suppose the sikorsky is in the middle of the sea...Disapprove [V](suggestion needed)
Maybe I can create the scene in a beach and try to hide the support with a palm three or something(i have seen some of them in other dios) but do you think the beach would be a potential extraction zone for a seal team?Question [?]Dead [xx(]
i have seen something of the groupbuild but dont know how does it work, can you tell me something about it?Question [?]
thanks a lotTongue [:P]Big Smile [:D]Smile [:)]
Pedro
    March 2004
Posted by DanCooper on Tuesday, January 18, 2005 7:39 PM
Basicly a GB is a bunch of people building something withing certain parameters (can be the same scale, subject, place, battle....whatever what has been agreed on), and along the line the participants share ideas, pictures and advise to one another.
    March 2004
Posted by DanCooper on Tuesday, January 18, 2005 7:40 PM
Oh by the way, I'm not an expert on these things, but wouldn't a seal team been extracted with a Blackhawk instead ???
Posted by HeavyArty on Tuesday, January 18, 2005 8:02 PM
Here is a link to an old thread where they talk about building a Blackhawk Down Dio with the helo supported by metal rod hidden in the Fast Ropes.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=2329
And a pic of one of our member's (Avus, Klaus Pagano) supported UH-60.
Here's his website too. (Go to Aircraft and scroll down.)
http://www.avus.esmartdesign.com/
Hope tis helps.
