Aircraft tarmac
    May 2003
Aircraft tarmac
Posted by styrene on Friday, January 21, 2005 9:12 AM
Sorry if this question may have been asked here before; I don't frequent this particular forum as much as others.
Where does one purchase aircraft tarmac to fashion 1/48 bases? If you make your own, how do you go about it?
Thanks for all the help.Smile [:)]
Gip Winecoff
    January 2004
Posted by knight667 on Friday, January 21, 2005 10:46 AM
This is what I use:
http://www.squadron.com/ItemDetails.asp?item=VE1632
Looks pretty good to me. Other people use different techniques; it's been discussed before, but it never hurts to ask again. Big Smile [:D]
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    May 2003
Posted by styrene on Friday, January 21, 2005 11:30 AM
John,
Thanks for the link!
Gip
    January 2004
Posted by Ali1kj on Friday, January 21, 2005 4:28 PM
Use wet'n'dry paper and spray with a concrete colour....simple to do and somewhat cheeper !!
AJ
Posted by ponch on Friday, January 21, 2005 4:44 PM
I use a sheet of styrene, and scribe in the expansion panels. Then airbrush a mixture of gray and black to make it look like concrete, and accentuate the panels with black, being a bit sloppy so it looks like the asphault filler (at least I think it's asphault, maybe somebody else out there knows what the black stuff is Smile [:)]). Add some grime with pastel colors, and the occasional oil stain and you're done. I did the tarmac in the diorama below using this technique.
Smile [:)]Smile [:)]
    May 2003
Posted by styrene on Friday, January 21, 2005 5:56 PM
AJ, thanks for the advice. Yes, it is quite a bit cheaper!!
Ponch, thanks for the idea and the great visual aid to boot! What a great looking diorama!
Gip Winecoff
Posted by Anonymous on Friday, January 21, 2005 6:31 PM
i cut sheets of balsa wood (the ones that are about 3"x1/8") into perfect squares, glue them down onto your base, then spray on some of the "stone" finish spray paint, then sand it down so it isn't so rough. After that i use putty to fill in the cracks and then paint it black (it's OK if a little runs over the edges--it looks like Tar) After that, i just airbrush a mix of black and some brownish colors onto the cracks to make it look a little more weathered.
Example:
Note: I made my cracks too big--don't leave that much space in-between ;)
