Diorama No. 11 Progress Pics of Dio Base
    July 2003
Posted by Dwight Ta-ala on Thursday, January 27, 2005 6:16 PM
Got a bit of progress last night on the ruins for my next diorama. I already added the street, sidewalks and an additional ruined wall across the street.
The white stuff you see is wall putty that I used to seal the edges of the foam board as well as add some texture to the walls. I will be sanding them a bit later.
The ruins and the street have been scratchbuilt from foamboard.
The door and window frames as well as the floor are from popsicle sticks. Actually the floor pieces are a bit thick for scale but I did not bother to do a thing about it.Big Smile [:D]
http://img.photobucket.com/albums/v626/Dwight_Ta-ala/Model%20Pictures/100_2332.jpg
http://img.photobucket.com/albums/v626/Dwight_Ta-ala/Model%20Pictures/100_2330.jpg
http://img.photobucket.com/albums/v626/Dwight_Ta-ala/Model%20Pictures/100_2329.jpg
Smile [:)]
    February 2016
Posted by duckman on Thursday, January 27, 2005 6:22 PM
looks good Dwight
On The Bench:
Revell- 1/72 Messerschmitt Me P1099
Posted by Anonymous on Thursday, January 27, 2005 6:26 PM
That looks great Dwight. I really enjoy your dios. I truly try to follow your suggestions. I think that your dios are great and they are an inspiration to me. Thanks for sharing!
    July 2003
Posted by Dwight Ta-ala on Thursday, January 27, 2005 6:30 PM
Thanks guys. I added the links to the pictures. The forum page doesn't allow them to be viewed at the right size.
    October 2003
Posted by rebelreenactor on Thursday, January 27, 2005 6:42 PM
How did you make the street and bricks on the building? they look really good!
John
    July 2003
Posted by Dwight Ta-ala on Thursday, January 27, 2005 6:49 PM
Materials:
1.) 6mm (1/4 inch) Foam Board. Comes in black or white but I had the black one. It is basically medium density foam sandwiched by thick paper (not really cardboard) Note other thickness are available but this is the most common in the art supplies stores here.
2.) White glue
Tools: (well I don't have to but I'll just list them down just the same... Smile [:)] )
1.) Cutter
2.) Ruler or Straight Edge
3.) Pencil
4.) Cutting mat (or whatever that will prevent my wife yelling at me when she sees that I scratched the dining table again...Big Smile [:D])
5.) Pins
Procedure:
1.) Draw the desired form of structure wall (include the doors, windows, etc.). You may need some 1/35 scale ruler to get better dimensions. Do this for each wall face you need.
2.) Cut off the entire wall face from the board. Also cut off the openings like doors and windows.
3.) Draw outlines of the plaster.
4.) With the cutter retrace the outlines lightly just through that the covering paper. Do not cut any deeper.
5.) Peel off the paper on ares where you want the bricks to be exposed.
6.) When you peel off the cover paper, you will have a surface of foam. Draw lines to represent the bricks. Do this in all exposed foam areas. Retrace the lines with the cutter cutting only about 1mm into the foam. Be careful as the foam is very soft and can be cut easily.
7.) retrace all the cut lines with a ball-point pen. This is to widen the gap a bit to accept the white paint (simulating mortar paste) during painting.
8.) Add all the other things like ledges, canopies, etc.
9.) Joint all wall faces together. Use the pins as nails to hold the faces together while the glue dries.
10.) Now you have the basic structure of a ruin.
The street was done by simply cutting lines on the foamboard surface and retracing the said lines using a ball-point pen.
Smile [:)]
    August 2004
Posted by Tankmaster7 on Thursday, January 27, 2005 6:51 PM
looking good. you're inspireing me to try my first diorama.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Thursday, January 27, 2005 8:19 PM
hey that's pretty awesome! can't wait to see it all painted up!
    October 2003
Posted by rebelreenactor on Thursday, January 27, 2005 9:33 PM
deffinetly going to have to try this one! thanks dwight!
John
    April 2004
Posted by yw18mc on Thursday, January 27, 2005 9:34 PM
Fantastic work Dwight. You make it sound so easy, your instructions are perfect for us who have never experinced the scratch building process. Hope you continue keeping us in mind as you progress through the fabrication of what will be another winner build. As always thanks for helping us to see, and understand all that goes into building these works of art. Semper Fi,mike
mike
Posted by Anonymous on Thursday, January 27, 2005 10:35 PM
Nice dwight. I hope someday to be able to do what you do.
In the first pic, is the tank to the left going to be in the dio?
    July 2003
Posted by Dwight Ta-ala on Thursday, January 27, 2005 11:34 PM
Thanks guys, I'll keep you updated on this one.
Posted by Anonymous on Friday, January 28, 2005 2:25 AM
Great work, and thanks for going into detial. Sometimes we forget if nobody went into detail there would be no detail...are something like that...Anywayzzz you've given me a cheap alternative to plaster and for that my wife thanks you.
    November 2004
Posted by sasd on Friday, January 28, 2005 8:23 AM
Great stuff Dwight,your rundown on the procedure is excellent,gonna be a beaut! One question,I have had a hell of a time cutting foamboard in the past,what kind of cutter are you using to cut this stuff?
russ
"Battleing Bastards of Bastogne"
Posted by Kelly_Zak on Friday, January 28, 2005 10:09 AM
Russ, get yerself a table saw, and a compound mitre saw! LOL! Actually, when I go to HD to get my sheet of foam, I'll try and pick up cool little saw that my father uses for his plumbing stufff, it works great on anything! (oh, did you get youf foam yet?)
Back at hand: Dwight, very impressive! I love the statement 'bout the floor thickness being out of scale, and who cares? LOL Great! Can't wait to see this puppy all finished. Hey, I use popsicle sticks too! But you know what is really good for stuff like fencing, floor boards, etc? Next time you're in Starbucks or a coffee shop, and they have those wooden stir sticks? I always grab a hand full when I get coffee! The fence section in my Passing Through dio is said coffee stir sticks! haha
"There you go with those negative waves again!"
    July 2003
Posted by Dwight Ta-ala on Sunday, January 30, 2005 6:37 PM
Russ,
I use an ordinary cutter that we use here in the office the one where you can refill the blade and where you slide the blade to snap the dull section off to get to the sharp one.
Thanks for the comments guys...
