brick building question
    February 2005
Posted by Kevleerey on Tuesday, February 15, 2005 5:54 PM
I am building a brick building for a diorama. It is 1/4 inch thick, made of plywood with a layer of joint compound on the outside. I am going to carve a brick pattern in it, but I dont know what size to make them. Also, the inside is supposed to look like plaster, but it is bright white. What color should I stain it? Thanks for any help.Cowboy [C):-)]
Posted by Anonymous on Tuesday, February 15, 2005 6:32 PM
I'm not sure about the brick size, but you could always try going down to a home depot or other hardware store chain. Thry will probably have bricks you could measure, then divide it by whatever scale your dio is. Good luck. And post some pictures!
    October 2003
Posted by rebelreenactor on Tuesday, February 15, 2005 7:57 PM
custom dioramics makes some 1/35 bricks that you could use as a measurment. But it would probaly work if you did it by how it looked and carved as you went along.
for staining, not quite sure what you mean on the 2nd question. Try painting it with primer, then white paint, and then give it some oil washes of burt sienna or burnt umber and black for a worn look. For a non blown up building, I'd use a light gray wash.
you can also buy scale wall paper.
John
Posted by Kelly_Zak on Tuesday, February 15, 2005 10:26 PM
I do alot of my own brick scribing for my buildings, I kind of just wing it, but I do use a rough measurement as a guide. 2mm wide x 4mm long should work, hell I usually end up with different sizes, so it's not going to really matter too much.
As for the interior, go with whatever your imagination comes up with. If you want to do a plaster look for the interior, try using an off white color, say a Antique White craft paint, then do some dark washes, and pastels, etc.
If you go the wallpaper route, there are downloadable designs, or you can buy some. I buy some photograph album scrap paper sets, and use them. A word of caution. (And I found this out the hard way) if you use a paper product, I wouldn't add a wash to it, I did and lost all of my designs! I would go with straight pastels in this area.
Cheers,
Kelly
"There you go with those negative waves again!"
    February 2005
Posted by Kevleerey on Tuesday, February 15, 2005 10:48 PM
Thanks! I will try to get some pictures if i can.
Posted by Anonymous on Wednesday, February 16, 2005 8:08 PM
I'm measuring a 1:35 scale brick from the Tamiya brick wall set,I get 2mm.tall,8mm.wide.
    February 2005
Posted by Kevleerey on Wednesday, February 16, 2005 10:26 PM
How do you put picures on here?? I have them on my computer, but i cant copy/paste or drag and drop them, and again thanks for the help everybody!
    February 2005
Posted by Kevleerey on Thursday, February 17, 2005 4:06 PM
Finally!! Pictures!!
The building is not attached to the base yet, and also I am going to repaint it after the bricks are carved, but you get the idea of what it will look like. The white walls (inside view) are going to look like plaster, and i havent decided whether the building was bombed or just collapsed. I thought it would be fun to do part of the interior not burnt. I cut balsa floor joists and floorboards. They are broken on the ends and i still need to stain them too, but I dont know what color to use to make them look weathered. Thanks for any tips!Smile [:)]Oh well, heres a link. WHY WONT MY PICTURES WORK???
http://rongeorge.com/modules/Gallery/upload/Grabbed_Frame_1
http://rongeorge.com/modules/Gallery/upload/Grabbed_Frame_2
Posted by Anonymous on Wednesday, February 23, 2005 12:21 AM
custom dio uses 7mlx3ml Good luck broBlush [:I]Blush [:I]
