Just won't dry, leak promblems
Posted by Anonymous on Wednesday, February 16, 2005 2:22 PM
OK lets give it a try. Thats what I said as I squirted futer into a carved stream bed in styrofoam. The only promblem is that it leaks through the styrofoam. I don't to waste any more money trying to figure out a solution. Does anybody have any ideas?Question [?]
    June 2003
Posted by Duke Maddog on Wednesday, February 16, 2005 3:14 PM
Did you coat the inside of the streambed with anything? If not, try to 'seal' the streambed area with a mix of 75%-25% white glue to water. Put a couple of coats on if you feel it is necessary. Paint all the way up to the sides and top of the banks of the stream; it'll add to the wet effect at the top of the bank. Then, you should have a smooth, almost plastic-feeling surface. Paint the streambed with a dark brown color for the bottom once it's dry. Block off the ends of the streambed as best as possible, and try adding the Future again. Do it in layers if about a mm or two at a time and let each layer dry before you add the next one. Then, as these layers dry, you can always tint them with clear browns, yellows and greens to give it a 3-D stream effect that will add to the look of the stream. Each color above the lower one should be a bit more light and diluted than the one below.
Good luck with this. I hope it helps. If it does, please post pics so we can all see how it turns out.
    October 2003
Posted by rebelreenactor on Wednesday, February 16, 2005 5:46 PM
you can also use woodland scenics flex paste.
John
Posted by ajlafleche on Wednesday, February 16, 2005 7:50 PM
Using Future to create a stream is going to take you an eternity. Why not just go out and get some Liquitex. It's a two part very clear epoxy designed to replicate water. I just did a stream bed a quarter inch deep in two applications over two days. Superhard, glossy finish. It's a lot thicker than Future and is less likely to seep through.
Basic adage of life: Always use the right tool for the job.
    February 2005
Posted by Kevleerey on Wednesday, February 16, 2005 10:33 PM
what do ou use to tint the water? I tried paint but it just looks bad.
