how to "blow up" vehicles?
    February 2005
Posted by rufioizgrreat on Friday, March 4, 2005 9:25 AM
i need to make my BMP look like its been taken out by an M1. how do i go about doing this? ive seen some pics with the roadwheels taken fully off. i had an idea of heating up the body and cutting and bending it up to make it look blown out. i know i need pastels and rust and black colors. any advice? very inexperienced around this area. cant find many photos of destroyed BMPs either.
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time." -Lewis B. "Chesty" Puller
    July 2003
Posted by Model Grandpa on Friday, March 4, 2005 9:35 AM
Just remember armor plate really doesn’t bend, it breaks off in chunks. The parts that bend would be like storage rack & binds, fenders, etc. Some “shaped” rounds might show a slight melting around the entry point.
*Sorry if my terminology is slightly off I’m primarily an aircraft guy, but I’m learning.
Regards, Dan Building Scale Models At The Speed Of Dark
Posted by Anonymous on Sunday, March 6, 2005 6:57 AM
find some books on desert storm ( concord, squadron/signal,etc...) and you may not find a bmp, but i'm sure there is something similar.
Posted by Anonymous on Monday, March 7, 2005 3:08 AM
There is a great Concord book on the BMP family. I can E-mail you some of the pix from the book of blasted bmp's if you like? Sorry but at the moment I am at work and cant remember the name of the book. I will reply when I get home.
Posted by Anonymous on Wednesday, March 9, 2005 3:38 AM
Well sorry about not replying yet. My wife thought she was going into labor, that really throws off my schedule when she does that...Dont worry I have not forgot about you.
    June 2004
Posted by clfesmire on Wednesday, March 9, 2005 8:00 PM
Before you go destroying the model. Take some heavy guage aluminum foil and lay it on the specific parts you want damaged. Burnish the foil to the shape of the section of interest and then you can "damage" the foil easily. If necessary, cut out the damaged section and replace it with the foil. This looks very realistic on military pieces as well as that passenger car you wish to have had an accident
Posted by Anonymous on Wednesday, March 9, 2005 9:09 PM
Why blow it up? Clown [:o)]
I did my Shock-n-Awe to capture the moment just before impact! Evil [}:)]
All you need is a fighter plane to steal some parts from Tongue [:P]
Or in your case, scratchbuild a 120mm projectile.
Posted by Anonymous on Wednesday, March 9, 2005 11:26 PM
Ok I have been doing some research and it depends on the weapon that hits the BMP and where it hits it at. For example, an RPG that strikes the BMP in the rear will cause the vehicle to explode nicely. Most BMP have two doors in back and the doors are feeled filled with fuel, also the ammo is stored in a ring around the base of the turret. And if the ammo is hit or set off the turret explodes and flies off the BMP. Now in one of the books I have a BMP-1 was hit by a SABOT round at the base of the turret. This round did not set off the ammo and did not hit the fuel. Instead it went in the turret damaged the gun and killed the commander and the gunner. There is small hole with some flashing scattered out from the hole and the loose equipment on the BMP is knocked around. But other than that the vehicle looks ok. So. I quess what I'm saying is it depends on how much time you want to put into it. If you have the time and resources I quess you could have the turret blown off and show all the detail inside. And if not then you could go with the small hole and so on.
The two books I have that show some "ok" damaged and blown up BMP's include "The War In Afghanistan 1979-1989" BY David C. Isby And "Sword In The Sand, U.S. Marines In The Gulf War" BY Tony Engelhart And Pat Foran. Both books are published by CONCORD.
If you need detailed pix and drawning of the inside of the BMP and family check out "BMP-1 Soviet Armoured Fighting Vehicle In Detail" BY Wings and Wheels Publications, Photo Manual for Modelers. This book is by far the best for inside referances!!! And "Russia's BMP Infantry Combat Vehicles" BY Steven Zaloga and David Markov, CONCORD published.
FINALLY once you decide on the amount of detail you want, post again on the subject and I can help you some more.
(PS) I know I sent you this in a E-mail but I thought there might be others that would benefit from this info. so I posted it here as well.
    February 2005
Posted by rufioizgrreat on Thursday, March 10, 2005 2:08 PM
sadly, before i had recieved the emails, i had already gone to work destroying it. i just used an old pocketknife, a candle, and my imagination. probably not super realistic, but for me, i think its ok. i held the model over the candle to warp hatches and the doors, and heated the knife to cut holes out and damage the side armor. just need to color it. will post when finished. thanks guys!
Posted by Anonymous on Thursday, March 10, 2005 2:15 PM
Try a Google search under "Destroyed Tanks" there are some good links here are 2 one of which is just what you were asking about
www.gulflink.osd.mil/ du/fig24.htm
www.Defense-Update.com
Hope it helps??
    March 2004
Posted by DanCooper on Sunday, March 13, 2005 2:44 PM
Can you perhaps post some pics of this process, I would really love to actually visualize this.
On the bench : Revell's 1/125 RV Calypso
    June 2004
Posted by clfesmire on Monday, March 14, 2005 6:49 AM
This is a technique used by model railroad guys for some time in creating wrecked cars for junk yards and truck loads. Here's a link to an online clinic:
http://www.horailroad.com/a_onlineclinics.shtml
    July 2004
Posted by jaysun on Monday, March 14, 2005 11:42 AM
That is a great link. There is a great shot of a APC taken out by somali troops in the Documantary Black Hawk Down. A totally great shot. Just pause the DVD and copy away.
I love the smell of super glue in the morning. Smells like...victory.
    January 2005
Posted by jinithith2 on Wednesday, April 13, 2005 7:51 PM
here's an idea (although u might have completed this by now)
I was working on my Abrams and when I drybrushed a little too much black, I said oh what the heck and I added some explosion like blast thingy to simulate RPG hit
Posted by Anonymous on Wednesday, April 13, 2005 10:03 PM
If you want check out the cold war GB, I have some pic's of my destroyed T-55, I used some metal, bent it, cut it and super glued it into place.
