Building Walls And Houses
Posted by Anonymous on Tuesday, March 22, 2005 11:42 AM
I want to create some walls and houses. How do all of you create walls? My main problem i think is how to get a wall i made to stand up on base.
My main materials i have to use right now are. Plywood, Presentation board, misc wood , some stryene.
Any tips ,examples , web sites etc.. Would be great and i think help out lots of people also.
Posted by Anonymous on Sunday, April 3, 2005 5:22 PM
im new but im using clay from hobby lobby to create my walls and they are turning out great
Posted by Anonymous on Sunday, April 3, 2005 7:10 PM
Yeah I use that it seems to be the best way that I have found to do that as well. I actually used styrofoam once and that seemed to be ok to but only if you dont have any other ideas. Big Smile [:D]
Posted by Kelly_Zak on Sunday, April 3, 2005 10:58 PM
Although the material is different, the methods of attaching to bases should be the same. I usually use five minute epoxy to attach my buildings to the base. Same goes for attaching the sides of the buildings together.
My main material I use is plaster, which I simply use big lego blocks as a form, pour the plaster, let it cure, and cut and shape as needed. Walls can be scribed from either a dental pick, or the back side of a hobby blade. If you're using wood/styrofoam for your main material, you can use white glue to attach to the base. And, even use cork to cut individual bricks and glue them to the wood/styrofoam.
"There you go with those negative waves again!"
Posted by Anonymous on Tuesday, April 5, 2005 12:44 PM
I guy in another forum recommended this stuff:
http://www.dickblick.com/zz331/11/products.asp?ig_id=1974
And it is wonderful. Simply great to work with and carve
(Thanks KennethC)
Ted
Posted by Kelly_Zak on Tuesday, April 5, 2005 2:01 PM
Ah, balsa foam....wish our LHS carried this stuff, can't get it here in Victoria, which sucks. And it's a bit pricey for what you get, a friend managed to get some, and it looks marvelous!
Posted by Anonymous on Wednesday, April 6, 2005 8:12 AM
    February 2005
Posted by Kevleerey on Monday, April 11, 2005 6:01 PM
You can use plywood and put a layer of plaster over it and then sand it down smooth or carve it
