- Member since
Posted by Kelly_Zak
on Wednesday, April 13, 2005 10:57 AM
I've used tile grout for ground bases, it works quite nicely. See my "Shellshocked" dio somewhere around here....Latex tile grout, I don't know about that, never used it, just the non-sanded kind. I just poured on the stuff dry roughly spread it out to where I wanted it, lightly misted it with water, and added white glue/water so it cures harder. You could pre-mix it with water and glue first and add it to your base and shape it as you see fit. Remember, if you are going to have vehicles in the scene, make sure you have them ready, and while the grout has hardened slightly, press the vehicles into it to create ruts and track/wheel marks into the ground, you won't be able to do this once it's fully cured. Good luck!
"There you go with those negative waves again!"
