How to Create Racing Surface for F1 Car
Posted by Anonymous on Thursday, May 5, 2005 4:31 PM
I have a 1:18 scale BMW FW24 Formula One car in a wood and glass display case. I would like to create a road racing surface to fit into the display case and simulate the car going around a corner - showing the road and some of the grass infield. What materials or methods should I use to create this base or are there any links to websites that would have useful information? I am a novice to building dioramas, so any help is greatly appreciated!
    April 2004
Posted by vespa boy on Friday, May 6, 2005 8:45 AM
try using a sheet of wet and dry carbide paper glued to the base. If you choose the right grit it will be in scale and have the smooth even texture of F1 tracks.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
Posted by Anonymous on Tuesday, May 10, 2005 8:50 AM
Thanks Vespa. I appreciate the tip. That will make the largest portion of the base easy to make.
    July 2003
Posted by oldhooker on Tuesday, May 10, 2005 9:35 AM
Hi boggs, and welcome to the Forums! Smile [:)]
Here's a display I made a couple years ago, which creates the illusion of the car being in-motion:
I built up the track suface with foam, overlayed with sheet styrene, and painted it different shades of gray, streaking it lengthwise. The white line is faded on either end, the wheels were turned on a lave with fine grade sandpaper. The wall is made of sheet styrene, both ends painted red, with red airbrushing where the red & white come together. The tires were mounted with the smooth side out, and the raised lettering blur was created by simply masking off the letters height, dabbing a bit of flat white in the middle, then smearing it in both directions.
I mounted this picture on the inner backside of the display case to complete the illusion.
It's a simple technique that creates an in-motion effect for the viewer. (especially if you take a picture of it outside in the sunshine!) Wink [;)]
Just some ideas...
Take care,
Frank
Posted by Anonymous on Tuesday, May 10, 2005 12:32 PM
Holy cow, Oldhooker. That's ingenious!
    July 2003
Posted by stukabomb88 on Tuesday, May 10, 2005 12:43 PM
Oldhooker, that's amazing!!! I serously thought, before reading it, that the first picture was real!!
"If you live for personal gain, you have lived in vain." -Devon OpdenDries
Posted by Anonymous on Wednesday, May 11, 2005 4:15 AM
Great pics and some great tips as well.
Thanks Old Hooker.
Cheers , Pete.
Posted by Anonymous on Wednesday, May 11, 2005 6:03 AM
I've tried the sanding paper as well with the BMW 1200 R I built.
Still, perhaps it might be an idea to create an asphalt mix your self. I'm thinking of a mix of (fine/rough?) sand and white glue, perhaps colored in advance.
Anyone tried this? I guess it's not much different from the mud-making the armor-builders use.
    April 2004
Posted by vespa boy on Wednesday, May 11, 2005 10:15 AM
svankreijl, I've made my own gravel mix with different grades of carbide grit and it works well with PVA. I also mix in different coloured particles etc. Look at real road for a while and then do it in miniature. You still have to paint and weather it after its made. but the texture is right and that's crucial.
F1 track is amazingly smooth and carefully prepared which is why wet and dry paper is a good place to start. You then have to weather it etc.
Posted by Anonymous on Thursday, May 12, 2005 1:45 PM
Just some ideas...
Take care,
Frank
Wow.
Posted by Anonymous on Monday, May 30, 2005 1:38 AM
Oldhooker,
Amazing diorama. And excellent ideas. I really appreciate the help. Time to rethink my setup.
Posted by Anonymous on Monday, May 30, 2005 2:02 AM
thats not the 1st time ive seen that dio, but man, its stunning!!!
great job!
