My 2nd dio
My 2nd dio
Posted by echolmberg on Thursday, May 26, 2005 12:29 PM
Hi everyone!
This is the second small diorama I've ever done and I got a LOT of tips from this forum. Some of you may have seen my P-51 sans base when I posted it in the Aircraft section.
The tarmac part is sandpaper which I painted grey. I smudged a bunch of stuff on it to try to give it a very worn look. I used graphite, India ink, pastels, and dirty thinner to simulate stains and spills. For the seams I used Elmers glue mixed with a bit of Poly Scale black and applied with a fine point brush.
The groundwork is, well, ground. I got a bunch of it when they turned the field next to my house (where I used to do my RC flying) into a subdivision. I ran the dirt through a strainer then poured it into a mixture of water and white glue. The grass is the kind used in model railroad scenery and where you might see some lighter earth peeking through is, in fact, Nestle's hot chocolate powder mix. I was truly amazed at how closely this replicated the look of a picture of a similar setting I found in one of my reference books.
Anywho, I wanted to thank everyone in the forum for sharing their creativity which helped me make a nice little "snapshot" diorama. This one is going to my dad for Father's Day/his birthday in June.
Best wishes to all,
Eric
    April 2004
Posted by crockett on Thursday, May 26, 2005 12:44 PM
Looks very well done. I like the presentation and the airstrip detail. One thing for future reference, if you're into realism, the P51 should be posed either with the gear doors up and flaps up, or the gear doors down and flaps down from what I understand. It seems the hydraulic pressure would slowly bleed off after a while and flaps and gear doors would drop together.
Good job on your small dio
Regards,
Steve
Posted by Anonymous on Thursday, May 26, 2005 1:29 PM
Great diorama echolmberg.
Smile [:)]
Posted by echolmberg on Thursday, May 26, 2005 1:46 PM
Steve,
I know what you mean about the flaps and gear doors bleeding down. This is the Hasegawa Mustang which, unlike Tamiya's, has the flaps in the "up" position. In retrospect I should probably have left the gear doors up or at least down just a crack. Oh well. At the time when I bought the kit it was less expensive than the Tamiya kit. This was my first Hasegawa P-51. I had always heard some good and not so good talk about it and I wanted to see for myself how it was. Yeah I wish the flaps were dropped but I would get the kit again because it does have many other good things going for it. But I know what you mean. Having the flaps up like that sort of bugs me a little. LOL!
Thank you for the kind remarks. Happy modeling!
Eric
