First let me tell you about Lemax. This company makes Christmas Village pieces from
buildings to footbridges to trees. They either come in ceramic or plastic,are prepainted
but that can be changed easy enough. The trees are either realistic or Christmassy and everything is usefull at somepoint. Micheals is a big carrier of this line and I gotta tell you there`s some pretty neat peices in this stuff! There is now also knockoff stuff available from Canadian Tire and other department stores.
Now having said all that the picked fence,wrautiron fence and the streetlamp are all from Lemax,repainted and weathered.The building fasads are shapes of insulation foan cut,glued together,painted and weathered. Real crushed brick,sidewalk is cut cork bricks glued directly to the base and the powerpole is a piece of dowl drilled into the base. Hope this helps. Have fun
"Battleing Bastards of Bastogne"
