jinithith2;
The above two posts are correct. I have also used the extra track or a spare track picked up at a hobby show. I superglue a length around a spare road wheel or piece of round stock and attach it to a coat hanger armature. It is basically like making a miniature paint roller.
With the "track wheel" in place on the armature I give it a light dusting with talcum or use some DRY mixture that you're using for creating the groundwork i.e. celluclay, plaster etc. This keeps the "trackwheel" from becoming clogged and leaves clear imprints in the groundwork. Then I just simply roll into the fresh laid ground work before applying the static grass and colour etc. Two important things to remember are spacing the track ruts to match the width of the vehicle and second is you are replicating a heavy object traversing over soft ground. Even hard sun-baked desert will result in some impression made as the tank rolls across the landscape that's why I roll first before applying colour or static grass etc. you have to think about the force being applied by the weight of the vehicle. It will compress the top of the surface into the track rut. That is why I lay in the colour afterwards and then the static grass etc. it creates groundwork similar to the real thing. I hope this is clear enough.
Your second question was what do you use for dirt. Well again a straight forward answer is use real dirt. However, don't just go to the garden and dig up a chunk and try and glue it down. There are a number of books totally dedicated to the subject that I have found invaluable for creating realistic terrain. Here's a short list.
1. Terrain Modelling Masterclass - Osprey Books
2. How to Build Dioramas Vol.'s 1 or 2 Sheperd Paine - Kalmbach Publishing
3. Landscape Manual - Model Railroader- Scenic....(Forgot the rest) Sorry
Each has really easy instructions to make any type of terrain and how to improve your already existing skills. If you need anything further reply here, or feel free to use my email address.
Cheers;
Gregory
