QUOTE: Um, Dirt and weeds from my backyard happen to be free |
QUOTE: ...The groundwork is simple to do, all I did was put down a bunch of sqaudron white putty,... |
Yeah but Sculpey and Squadron putty are ounce for ounce much more expensive than celuclay. So any savings you made by using dirt and stuff from your backyard are quickly eaten up by something that is considerably more expensive and better served by using it for its original intended use.
Unbraided and frayed cisal rope can be used for winter dead tall grass. Cheap clay cat litter makes great rocks and fine rubble.
You can "kick" your celuclay by mixing in some plaster of paris. This also gives some interesting texture and makes for a nice solid base. The thinner you make your celuclay layer, the less problems you will have with it (peeling up or cracking) and the faster you can work. Too thick and the top will dry faster than the under layer. This will make it peel up and away.
Celuclay comes in two colors, grey and white. While the white is more expensive than the grey, it has its advantages in doing winter scene dios with snow.
Score your base or ground surface before applying your celuclay so thit it has some bite. The mixing in of white glue with it will add to the adhesive quality and again result in less headaches later. I wait a bit before puttng in track marks, foot prints or other impresions. If too wet, the clay will reform and "swell" back into its form a bit. If you let it set up a bit first and while its still maleable then make your impresisons, the detail holds alot better. This comes in handy when making puddles in tracks or depressions.
Good luck and I hope we get to see some pics of your finished project. Or at least some in progress pics as you work on it.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
