Adding grass
Adding grass
Posted by Anonymous on Saturday, August 6, 2005 3:03 AM
hey
Just wondering when is the best time to add grass and ground coverings on a dio. I am using plaster of paris. Is it best to add them while the plaster is still wet or do I have to wait till it drys, and use glue?
Posted by Anonymous on Saturday, August 6, 2005 7:26 PM
I use celluclay and while still damp add the ground covering. I use static grass and tamp it down a bit into the wet celluclay. With shrubs and such, you can either add while still wet or drill small holes and glue into the dried plaster. I think while its damp you can make it look more realistic by working the plaster up around the shrubs base. Anyway, hope this helps.
    July 2004
  • From: ...Ask the other guy, he's got me zeroed-in...
Posted by gringe88 on Saturday, August 6, 2005 10:21 PM
if you're going to use plaster, id make sure to paint and weather it first, for dirt, then spread a thing layer (diluted with water) of elmer's white glue. then sprinkle the static grass down on that. personally i also use celluclay, as its easier to work with has a longer drying time, and is less likely to shatter than plaster (if you use it though, make sure to add a few drops of dish soap to the mix, it helps keep it from shrinking and warping when it dries).
the technique JGAGS mentioned works well for taller grass, not so much for the small stuff. i also find though that gluing grass right to the celluclay after the grass in the holes sets, provides a more realistic look, and the dried grass acts as a stabilizer for the grass being glued on
hope it helps
====================================== -Matt
Posted by Anonymous on Sunday, August 7, 2005 12:57 AM
Thanks for the help guys. I ended up just coloring the plaster, adding some trees while it was still wet then add the ground cover after it had all dried. I would use celluclay, it looks good to work with, but i can't find it anywhere. Might have to bye it over the net next time.
Thanks
    January 2004
Posted by cplchilly on Tuesday, August 9, 2005 8:54 PM
Im not sure what they call it down under wrc51 but celluclay is nothing more paper mache (ground up and pulverized paper product).
[img]http://members.fcc.net/ice9/badge.jpg
Posted by ajlafleche on Tuesday, August 9, 2005 10:43 PM
I use Celluclay for al my ground work, either directly on a base with holes drilled into it or over styrofoam for a deeper effect. I mix it with white glue and brown acrylic paint and throw in som HO railroad ballast if I'm doing bare ground. The easiest gras in 1/35 scale is Woodland Scenics fine turf. After your shaded and highlighted the dried celluclay, apply a thin layer of white glue and pour on some turf. If you want clumps of taller grass, drill some holes inthe dried celluclay and fold over some Woodland Scenics tall grass and insert these into the holes with white or superglue and trim to height.
    July 2003
Posted by zokissima on Wednesday, August 10, 2005 8:08 AM
I tend to add grass after the groundwork has dried and has been painted.
