1/32 fighter pilots?
    October 2004
Posted by nfpa1002 on Friday, August 26, 2005 12:06 PM
Hi what in the secondary market is availbe for like a F-14 fighter pilot in 1/32 scale ?
seated
w/o w face mask?
nfpa1002
    August 2004
Posted by Thehannaman2 on Friday, August 26, 2005 6:23 PM
I know Verlinden makes 1/35th scale WWII pilots and ground crew. See if theres anything in their catalog or on their website. The scales are VERY close and it is quite exceptable to "mix and match" 1/35 and 1/32. Also, check with other figure model makers to see if someone makes one in 54mm, which is close to 1/35th from what I understand. Someone please correct me if I'm off track here.
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
    November 2013
Posted by intruder_bass on Saturday, August 27, 2005 2:47 AM
Did you check any web stores?
They have everything you even dont know aboutWink [;)]
here you are:
http://www.squadron.com/ItemDetails.asp?item=CZF32092
http://www.squadron.com/ItemDetails.asp?item=AESGF43
http://www.squadron.com/ItemDetails.asp?item=VE2173
http://spruebrothers.zoovy.com/product/LEG4808A
http://spruebrothers.zoovy.com/product/WGZ0015
Good luck!
Andy
