Sealing Diorama Material
    June 2004
Posted by ewc2003 on Monday, September 26, 2005 8:31 PM
Ok guys,
First diorama in the process - actually just a base for an Sd.kfz 223 in Norway, 1940.
I used Woodland Scenics "Landscaping" starter kit for the grasses and stuff, and had some of their snow to use as well. What's the best stuff (other than their "Spray Cement" which I have found to be basically worthless.
Will pump style hair spray (Max Hold) work as a clear sealer?
Thanks for the advice.
Matt ------------------------------------------------- "The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke
    January 2004
Posted by Ali1kj on Tuesday, September 27, 2005 3:35 PM
IMEx Hair spray will yellow with age. It has a bad effect on some materials and can remain sticky when either humid of hot, This attracts dust as it sort of rises to the surface.
Really the only way I have found is good long term is to use woodworking PVAs under and or varnish as a very thinned spray top coat.
A Question guys, is the woodland spray gule just PVA thinned ?? sure looks like it
AJ.
