Easy way to build large Dios
    October 2005
Posted by sawdeanz on Saturday, October 8, 2005 11:53 AM
following is a technique i've been taught for making large dios. I don't know whether this is a common method or if any of you guys use it. It is a good technique for making mountains, hills, valleys etc., probably for large dios or large scale dios. you will need
screen (like pool patio screen), newspapers, a staple gun and wall plaster like what you can get at hardware stores.
To make the hill crumple up the newspaper tightly, put it on the dio base and kind of mold it into the shape and hight you want it. You will cut the pool screen to the aproximate size and use the staple gun to staple it to the base over the newspaper. Before you staple it all down, put more newspaper as needed to fill in the spaces and make the shape you want. Staple it all down making sure it is tight. you can create adittional flat areas, ditches, trenches, etc. into the hill by adding a staple to that area. Cover it with the plaster and use the plaster to make it more realistic. Surface as nessassary for your model.
I hope this helps anybody and i hope my directions were clear enough. I'll post some pictures as soon as i fugure out how to. Ask me any questions you have.
---Sawyer
Posted by Anonymous on Saturday, October 8, 2005 4:44 PM
Thanks for sharing, sounds very interesting!
Thanks,
Pisis
Posted by Anonymous on Saturday, October 8, 2005 10:59 PM
thats what train modelers do for landscapes, might look pretty cool applied to one of these models.-DJ
Posted by Anonymous on Tuesday, October 11, 2005 2:18 PM
I've seen it done before but with masking tape instead of screening. The tape held the newspaper down, and plaster-impregnated paper towels were applied over it. I'm not sure which way is easier, but plaster and paper towels might be cheaper.
    September 2005
Posted by Fish-Head Aric on Tuesday, October 11, 2005 3:08 PM
I intend to use some of these railroad layout techniques for a dio I am getting started with, recreating the following structure and scenery, plus model USCG boat, in 1/48 scale:
After the boat is finished I will be getting into the scene and show it once all is done, if not showing my successes and failures of the development process as well.
~Aric Fisher aric_001@hotmail.com
    July 2003
Posted by zokissima on Tuesday, October 11, 2005 4:47 PM
It's an interesting technique, been around for some time. May have to give it a shot one day.
