What should I use as a diorama base.
Posted by Anonymous on Wednesday, October 19, 2005 4:05 PM
What should i use as a diorama base? I have a homemade table that is 22x38 inches. Is there a way that I can build up so i can put trenches in. Should i see if i can find sheets of styrofaom so i can do a little sculpting to make it look natural? Also how should i cover the graound in a rock/snow/grass base, its a scene form the Ardennes front. What color should my base coat be. HELP ME please!!!
Posted by Anonymous on Thursday, October 20, 2005 5:14 AM
There are a few ways that you could do it:
1.) Wargamers method: layers of shaped foam boards covered with putty.
2.) Model RR method: chickenwire/wire mesh shaped and stapled to the base covered with plaster bandages/putty.
Those will give you your basic terrain shapes what you cover them with depends on what you want to represent.
As for basecoat/color I would go with earth/soil/dirt color.
The wire mesh makes for hollow terrain which makes it light-weight and allows for electronics, etc to be hidden, might also be good for other uses. Wink [;)]
    February 2005
Posted by Kevleerey on Thursday, October 20, 2005 6:39 AM
you can also use picture frames I think, or you could buy plaques or bases at some hobby store or a place where they make trophies or awards or something
--------------------------------------------------------------------------------------Kevin-------------------------
Posted by Anonymous on Thursday, October 20, 2005 11:47 AM
The styrfoam works the best for me, the model RR method is messy, and it can be hard to achieve the desired affect.
